ready for a pipe but unsure!!! - Page 2 - Road Glide Forums
Dragos BikeWorks
post #11 of 47 (permalink) Old 12-31-2012, 04:56 PM
Originally Posted by tj316 View Post
I'm changing cams also , pulling out the CR-575 and adding T-Man 625's , and changing pipes , everything else is being left the same
What change are you looking for from the cam swap?
post #12 of 47 (permalink) Old 12-31-2012, 06:02 PM
tj316's Avatar
It's a long story but basically we have had trouble tuning the pinging out of my motor , it is slight and only at 100% full throttle , Frank looked over my specs and he realize the CR-575 cams had to little over lap for 10.5 compression , they need 10.2 or less , with my head work a stock head gasket would have given me 10.19 , we used a .030 head gasket for 10.5 compression , to solve the problem I can go back to a stock head gasket or change to a cam with more over lap , Frank suggested cam change , I talked to Dan Baisley of Baisley Hi Performance who did my heads and he said if it was him he'd change cams , Frank and Dan both liked the 625 for what I wanted , torque starting at 2200rpm's all the way to 6000rpm's , a nice flat curve , other cams will get bigger numbers but not as good of a curve , so I decided to change cams over head gasket , I told Frank if I ever had to retune the bike I'd switch to the Dragula at that time , so here I am trying my hardest to stimulate the economy , the rest of you need to kick in and do your part lol
2011 FLTRX 120ST , CR-630i cams , Zipper's air cleaner, TTS tuner , Dragula2 pipe , Hawg Wired amp/speakers/tweeter grills , custom Mustang Seat, LRS 12" , Dakota Digital Gauges , BR 1 1/2" Sweeping Beater Bars , True Track Stabilizer, Ohlins shocks / Ohlins forks, Jagg Fan Assisted 10 row oil cooler & so much more TJ Sunny Florida
tj316 is offline
post #13 of 47 (permalink) Old 12-31-2012, 07:29 PM
connector's Avatar
Let us know how this works out. Italked to Frank about a year ago and i changed my cam for simaler reasons .Went to a T-Man 590 and couldn't be happier. And to the OP you can't go wrong with the Dragula
09 FLTR 103 Stage III
connector is offline
post #14 of 47 (permalink) Old 12-31-2012, 07:37 PM
tj I'll be stimulating the economy a little more when Hawgwired comes out with the new amps and I can get them from Frank. In the meantime I'm making subtle changes. And as long as I stop looking at your bike and the job you did with the fans, etc, maybe I can save some $$$$$, I still have to get shocks also. ....
Sent from my SPH-L710 using Motorcycle.com Free App
post #15 of 47 (permalink) Old 12-31-2012, 09:28 PM
Don't wait...call Frank.
I have a Thunderheader on my Lowrider, but I am excited about the Dragula I have on order for my glide!
13-FLTRX is offline
post #16 of 47 (permalink) Old 01-01-2013, 06:29 AM
tj316's Avatar
dbell , I keep looking at your bags and rear fender , you are trying to make me spend more money , the only thing holding me back is this orange won't match up so it means complete paint job to change
tj316 is offline
post #17 of 47 (permalink) Old 01-01-2013, 07:42 AM
Hey you started it, lol. And just think how much you can help the economy with a new paint job. BTW I may be changing the rear fender, check out True Kustoms G2 rear fender.
post #18 of 47 (permalink) Old 01-01-2013, 09:59 PM Thread Starter
OuchMMC's Avatar
SO I TALKED TO FRANK, HE GAVE ME GREAT INFO...BUT WITH ALL THE GREAT INFO CAME SOME DISSAPPOINTMENT. I DONT HAVE THE FUNDS TO DO EVERYTHING AT ONCE. PIPE INTAKE AND TUNER/DYNO. THEREFORE I NEED TO WAIT. AND SAVE SOME MONEY. WHILE IM WAITING IWILL BE LOOKING FOR SOME GREAT DEALS ON NEW/USED PIPES.. MAN I WISH I DIDNT LOVE MY RGC as much as i do lol OR ID JUST BUY A PIPE AND SLAP IT ON AND RIDE IT WITHOUT THE INTAKE AND TUNER.
2011 RGC STOLEN, 2012 RGC CUTOFF BY A FORD FIESTA!! 2011 RGC used with lots of accessorys! STAGE 4 103! CATCH ME!
OuchMMC is offline
post #19 of 47 (permalink) Old 01-01-2013, 11:06 PM
RichieRich's Avatar
Patience is your friend. Your bike will love you for it:thumbup:
2013 BBP FLTRX
RichieRich is offline
post #20 of 47 (permalink) Old 01-02-2013, 09:24 AM
I received my Dragula and PowerVision today!
Not bad turn around time, approx. 2 weeks from order date.
13-FLTRX is offline
