Engine Heat Shield for 2-1 Dragula - Page 3 - Road Glide Forums
Dragos BikeWorks
post #21 of 24 (permalink) Old 01-16-2013, 05:17 AM
You may have to go into map editing and click on it.
Drop bar menu will show
Then click on Auto Map. This will except fuel tables. It may be out of range on autotune.
Questions just call me .......
Thanks FD.
Originally Posted by Q-Hog View Post
I'm using the map that I got from frank.
DragoBikeWorks is offline
post #22 of 24 (permalink) Old 01-16-2013, 09:47 AM Thread Starter
Q-Hog's Avatar
Ok. Will do. I currently have map #236 that you programmed for me. You recently said to install map #197. I haven't changed it yet.
Q-Hog is offline
post #23 of 24 (permalink) Old 01-16-2013, 10:59 AM
Thats a big problem your timing is off........ with those cams. you need to install map we sent.
Thanks
FD
post #24 of 24 (permalink) Old 01-16-2013, 11:30 AM Thread Starter
Q-Hog's Avatar
Ok. Will do. The Tmax came programmed by you w/map #236. I recently inquired bout other maps then you recommended map #197. So I will install map #197 this week.
Q-Hog is offline
