Engine Heat Shield for 2-1 Dragula - Road Glide Forums
Dragos BikeWorks
post #1 of 24 (permalink) Old 01-13-2013, 09:51 PM Thread Starter
Q-Hog's Avatar
Frank, do you know of any engine heat shield that connects to the frame that can fit with your 2-1 pipe? I tried the one that HD sales and the bend in the pipe prevents it from fitting.
Q-Hog is offline
post #2 of 24 (permalink) Old 01-13-2013, 09:55 PM
Z-SHARK's Avatar
I'm very interested in this also for my Dragular.
Fill with Gas... Twist throttle... Enjoy Life
Z-SHARK is offline
post #3 of 24 (permalink) Old 01-13-2013, 10:17 PM Thread Starter
Q-Hog's Avatar
The heat emitting while riding slow is overwhelming.
Q-Hog is offline
post #4 of 24 (permalink) Old 01-14-2013, 05:30 AM
tj316's Avatar
I run the Kuryakyn one and it works or you can notch the Harley one
2011 FLTRX 120ST , CR-630i cams , Zipper's air cleaner, TTS tuner , Dragula2 pipe , Hawg Wired amp/speakers/tweeter grills , custom Mustang Seat, LRS 12" , Dakota Digital Gauges , BR 1 1/2" Sweeping Beater Bars , True Track Stabilizer, Ohlins shocks / Ohlins forks, Jagg Fan Assisted 10 row oil cooler & so much more TJ Sunny Florida
tj316 is online now
post #5 of 24 (permalink) Old 01-14-2013, 07:12 AM
+1, I have the Kury also.
Sent from my SPH-L710 using Motorcycle.com Free App
dbell66253 is online now
post #6 of 24 (permalink) Old 01-14-2013, 09:08 AM Thread Starter
Q-Hog's Avatar
Thx. Can you post a pic of it.
Q-Hog is offline
post #7 of 24 (permalink) Old 01-14-2013, 03:25 PM
No you would have to notch the HD one.
DragoBikeWorks is offline
post #8 of 24 (permalink) Old 01-14-2013, 04:08 PM
bigpete1's Avatar
i use the stock harley one with dragula .i notched it it works just fine easy to cut i will try to find a pic.thanks pete
05 fltri 95" 06 fxdi 95"03 flht120" 11 fltrui 103
bigpete1 is offline
post #9 of 24 (permalink) Old 01-14-2013, 06:45 PM Thread Starter
Q-Hog's Avatar
Thx . Do you have A close up pic?.. Those anyone have a pic of the Kuryakyn model installed with Dragula 2-1 that you can post? Thx
Q-Hog is offline
post #10 of 24 (permalink) Old 01-14-2013, 07:02 PM
Fire-Medic's Avatar
I'm worried about notching mine because they're match painted........
Fire-Medic is offline
