Wobble video - Page 4 - Road Glide Forums
Videos Videos with motorcycle content only please.
 2Likes
post #31 of 46 (permalink) Old 11-25-2012, 05:08 PM
Skratch nailed it. That's what it is 99% of the time. Ain't nothing wrong with new tires (99% of the time).
My '11 FLTRUSE same exact wobble. Maybe a bit worse. Wish the factory was better at the neck adjustment.
FGOWI is offline
post #32 of 46 (permalink) Old 11-25-2012, 05:43 PM
mitchdm's Avatar
They fixed mine last week at no charge HD will pay for it under warranty according to my boutique.
mitchdm is offline
post #33 of 46 (permalink) Old 12-19-2012, 02:45 PM
Wobble Video
I've got this same problem on my 2011 with about 7000 miles. Happens around 40 to 50 mph. Haven't dealt with it yet but it's fairly unnerving. Hopefully with this Video and the advice given here I can get it fixed while It's still under warranty.
Bigeasy is offline
post #34 of 46 (permalink) Old 12-19-2012, 03:01 PM
This has been an issue posted when this Forum first started. The dealer will say no all day long due to cost of everything from fall away adjustments to replacing a V up tire to a V down and Back to another V up. Key is call HD headquarters get a work order number give it to the dealership and don't stop until its fixed. Check your ride out before your warrantee expires! do not change anything on your bike prior to checking for this issue or you will be told to pound sand. Sad to say this is not something checked prior to you taking possession of your bike. (they uncrated a bike wiped it off and I pointed out to a dude to remove plastic off pipe before he started it. this was at another dealership i stopped at one day. So how would they know?
Frodoe is offline
post #35 of 46 (permalink) Old 12-19-2012, 06:07 PM
My 2013 FLTRU done this from day one worse with passenger and tour pack fall away is at 1 right now . Will have stealership check it out soon .
cbumdumb is offline
post #36 of 46 (permalink) Old 12-19-2012, 06:44 PM
I have a 2013 and I thought that dang wobble was going to throw me off. Haven't took it in yet to dealer
bruce hurt is offline
post #37 of 46 (permalink) Old 12-19-2012, 06:57 PM
ThumperGA's Avatar
My 2011 does the same thing...scared the CRAP outta me the third day I owned it when I was adjusting my gloves while coasting through 40 mph to a stop. Dealer said they "couldn't reproduce the problem"...just like they can't reproduce the high intensity vibration that is actually AUDIBLE in the front end as soon as I head into a corner.
I have a local independent shop telling me that's most likely the wheel bearings for the "humming" vibration and the head bolt for the wobble. I'm taking it in for a new rear tire this week and he's gonna check everything else out in the process.
**Cleverly Disguised as a Responsible Adult**
2012 RG CVO
ThumperGA is offline
post #38 of 46 (permalink) Old 01-21-2013, 09:10 AM
BCRG's Avatar
The wobble on my 12' was exactly the same, Dealer didn't want to fix it. The MoCo made them. The dealer just kept saying "this is normal". F*^%$G Doh!
BCRG is offline
post #39 of 46 (permalink) Old 03-30-2014, 10:57 PM
ccsolo24lal's Avatar
me too
I don't know how old this video is but I have the same problem it happens at lower speeds like when im coming up to a stop light and stuff. I have a 2012 why does it do it?
ccsolo24lal is offline
post #40 of 46 (permalink) Old 03-31-2014, 02:24 AM
skipperfltr's Avatar
I have an 08 and it has done it consistently since day one.........besides the other issues I have had,(4 pages of them) I should have gotten the Electra-Glide instead......anyway no matter what anyone has done to this bike, it still has the wobble, especially between 25-35 mph......no matter what the RPM is, I would imagine every r/g with this issue has a different speed as to where it starts, but it still could prove deadly. 3 Dealers have tried to remedy it, and mostly I was told it to be the tires........well, I have 2 brand new tires on it as of yesterday, Metzlers, and it still continues. I am afraid this will be my 1st and Last Road Glide, or even Harley for that matter, that I will own, And I have had DOZENS, since I have been riding them since the mid 60's. I still think its a frame/bearing or fork stem issue, but again, Harley will not would not return any calls, and the dealer mechanics are mostly dumbasses, hence I do mostly my own wrenching now. Good Luck!!!!!!!
50 States on a bike at age 50.
skipperfltr is offline
