Is "true dual" in the header? - Road Glide Forums
post #1 of 11 (permalink) Old 11-18-2012, 09:30 AM Thread Starter
DOOFUS's Avatar
Probably my stupid question for the 2012 calendar year:
I see Fuel Moto and others make a "header" for true dual performance.
Does that mean I can keep my VH Monster Oval "mufflers"?
Educate me -- thnx, DOOF
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #2 of 11 (permalink) Old 11-18-2012, 10:00 AM
tdkkart's Avatar
Correct, unless specified, these headers are designed to work with any standard aftermarket mufflers.
tdkkart is online now
post #3 of 11 (permalink) Old 11-18-2012, 11:56 AM
4getNo1's Avatar
Indeed, "true dual" is a term used for headers. Now, in case you wanted some casual reading (I'm bored)...
A real set of "true duals" has one individual pipe for each cylinder and those two pipes are totally isolated all the way to their own dedicated muffler. Some of us ol'pharts really like that old-time sound (or as close as we can come to it these days anyway).
Fuel-Moto (and other manufacturers including stock HD) use what's often called a 2/1/2 approach... two pipes at first but are cross-connected somewhere near the half-way point and then split back out into two different pipes for delivery to the mufflers.
This approach improves torque/performance but might not provide quite as much of a true dual sound as a set of real true duals does (pretty hard to tell the difference but if someone is really picky, well...)
Both of these "dual" types most often work with the stock or an aftermarket set of mufflers. IIRC, Some manufacturers used to mandate a specific set of mufflers (probably theirs) but not many do and they'll tell you if they do (want you to buy their mufflers).
Finally, there are the 2:1 type head-pipes and they are obviously not part of your question so no more casual reading
2013 FLTRX, Candy Orange
4getNo1 is offline
post #4 of 11 (permalink) Old 11-18-2012, 02:24 PM Thread Starter
DOOFUS's Avatar
Smarter Brothers -- thnx !!!!
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #5 of 11 (permalink) Old 11-18-2012, 02:33 PM
mocotom's Avatar
That summed it up very well. I would add that true duals will sometimes cause a dip in the torque curve between 2,000 to 3,000 rpm range that can be hard to eliminate when tuning. This may not occur, depending on your engine combo.
2005 RG 98cu in
mocotom is offline
post #6 of 11 (permalink) Old 11-18-2012, 03:00 PM
4getNo1's Avatar
Thanks mocotom and concur with you too on the slight dip with real true duals. The 2/1/2s might not sound quite as cool as real true duals but they're more efficient... one more choice each owner can make and why each of us eventually has an HD that became so damn expensive (she's mine dammit, my Harley, my way).
BTW - I really like those new rotors you got. Very nice.
4getNo1 is offline
post #7 of 11 (permalink) Old 11-18-2012, 03:05 PM
4getNo1's Avatar
Glad to help if we can - anytime.
4getNo1 is offline
post #8 of 11 (permalink) Old 11-18-2012, 03:35 PM Thread Starter
DOOFUS's Avatar
Well, ya gotta trust a fellow squid !!!!!!
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #9 of 11 (permalink) Old 11-18-2012, 04:08 PM
tdkkart's Avatar
Heh, I had a V&H 2-1 ProPipe that caused a massive dead spot in the power band on my Wide Glide, went back to the factory staggered duals with slip-ons and it went away.
post #10 of 11 (permalink) Old 11-18-2012, 06:16 PM
4getNo1's Avatar
You bet... saw yours too. I'm an old tin-can sailor that did a little bit of time fishing on some strange rivers.
4getNo1 is offline
