red line - Road Glide Forums
post #1 of 8 (permalink) Old 04-19-2017, 11:29 AM Thread Starter
red line
Is there anyone running redline 20/60?
Thinking about trying it to quiet down the top end?
dozer23 is offline
post #2 of 8 (permalink) Old 04-19-2017, 11:46 AM
I think harley jack does.
post #3 of 8 (permalink) Old 04-19-2017, 12:27 PM
NorCal's Avatar
I always run Redline 20/60 in the summer...it only quiets the top end only slightly
NorCal is offline
post #4 of 8 (permalink) Old 04-19-2017, 02:46 PM
HarleyJack's Avatar
yep HarleyJack runs 20-60 year round , no issues , great used oil analysis to boot , they have told me to extend beyond 8000 miles but I can't bring myself to that yet ..
I get mine from Racer Parts Wholesale , they have a kit with all the fluids in it ..
2011 Ultra
HarleyJack is offline
post #5 of 8 (permalink) Old 04-19-2017, 08:52 PM
MisterEd's Avatar
The only cure....rocker lockers or rock outs.
MisterEd is offline
post #6 of 8 (permalink) Old 04-19-2017, 09:24 PM
skratch's Avatar
I run it year round here also. while it doesn't really quieten down the top end, it does maintain a little more oil pressure when hot. where the 20w-50 would drop to 20 or less, the 20w-60 keeps up to almost 30. I know that it isn't a big deal, that these bikes are designed to run that way, but it makes me feel better
I don't bother with it in the primary or the tranny though. I use shell rotella t in the primary. it is jaso rated for wet clutch use and runs about $14 for a gallon of it. good for at least 3 changes. change it every engine oil change, 5k.
for the tranny, I just use a good synthetic gear lube. this last time I used supertech (yes, from Walmart. its mfg by citgo) and will change it out at the 40k on the odometer (20k on the oil)
skratch is offline
post #7 of 8 (permalink) Old 04-20-2017, 09:12 AM
PetesHog's Avatar
Are you guys running Redline is a M8 motor some are saying running Amsoil or Redline you'll get better easier shifting. I got 5000 on my 17 RGU 20w 50 SYN3 shifting is not has smooth as it was, Plus what oil are you using would 20/60 Redline work in a M8 Box
Live to Ride
IBA # 63744
PetesHog is offline
post #8 of 8 (permalink) Old 04-20-2017, 09:45 AM
Out
No, use red line gear oil with shock proof or Redline V twin tranny oil with shock proof in the transmission gear box. Red line 20/60 engine oil in the engine only. JMHO.
