Sest, PCV or PV - Page 2 - Road Glide Forums
post #11 of 20 (permalink) Old 05-26-2012, 12:57 PM Thread Starter
Thanks for all the input fellas. I am going to stick with the se tuner along with my other mods. Se heavy breather, Vance and Hines power duals and cfr slip ons. I'm going to also add a cam at some point.thanks again for all the input.
Bobbyl is offline
post #12 of 20 (permalink) Old 06-03-2012, 01:38 AM
Little late, but here goes!
As mentioned previously in the thread, installing any "version" of race tuner SERT or SEST, will leave a permanent footprint on your ECM and worse, void your warranty. These tuners marry themselves to your ECM and ... there's no denying it.
One thing no one's mentioned here is the throttle lag issues of the newer TBW bikes. If your unaware or simply haven't noticed it yet, rest assured it's there and not going away. The bigger you go with your motor, the more noticeable it will become. V&H has a partial fix, their ThrottlePak does help with the problem. The best solution, is the Zippers ThunderMax ECM, they discovered the problem with lag while developing their ECM. Just make sure you keep you stock ECM in case something goes wrong. Not advocating one tuner system over another, just helping inform people of the facts. Most dealers, locally, are now installing Power Commanders (with Dyno time) or similar piggy back systems that can be removed in the event of a warranty claim.
Food for thought!
Sidecar Cycles is offline
post #13 of 20 (permalink) Old 06-03-2012, 03:54 AM
Food for thought!
TTS has a great way of dealing with throttle lag. As far as warranty goes if you have built your engine so it needs a tuner, most likely your warranty on the engine is gone anyway. on the other hand if you have a good relationship with your dealer they will most likely take care of you regardless of what tuner you use.
jeff is offline
post #14 of 20 (permalink) Old 06-03-2012, 03:58 PM
hdxbones's Avatar
+1
Not saying it couldn't happen, but I have never heard of a warranty being voided for a SEPST.
If I were buying a tuner today, I'd choose the TTS
Ridin' Roadglides before they were cool.......
hdxbones is offline
post #15 of 20 (permalink) Old 06-03-2012, 04:34 PM Thread Starter
How can my warranty possibly be voided? They sold me the se pro tuner when I bought the bike...
Current rides
1997 Roadking
1998 Sportster
2005 Roadking
2012 Roadglide
Previous ride
2009 Streetglide.
Bobbyl is offline
post #16 of 20 (permalink) Old 06-04-2012, 10:26 AM
This is right out of the Screaming Eagle catalog:
"Warranty: Installation of Screaming Eagle products and off-road and competion products from other manufacturers, except some street legal offerings installed by a authorized Harley dealer may void your HD limited vehicle warranty. See your dealer for more information."
Now that being said they still have to show the modifacation caused the warranty issue in the 1st place.
roaddog is offline
post #17 of 20 (permalink) Old 10-01-2012, 02:24 PM
Site Sponsor
sloride's Avatar
My HD dealer told me when I bought the bike that if I buy the tuner from a authorized HD dealer and have them do the tune that it will in no way affect my warranty and that he will put it in writing.
2010 RGC Trike (Elvira)
110 CI, GMR 577 cams, Drago's 2.5 Heads & Exhaust
Stereo by "No Cage Audio"
sloride is online now
post #18 of 20 (permalink) Old 10-11-2012, 11:47 PM
Colin1966's Avatar
[QUOTEIf I were buying a tuner today, I'd choose the TTS][/QUOTE]
+1 on the TTS.
I like most here have used many tuners, PCIII/PC-V/THUNDERMAX & IED's I was about to pull the plug on a PV but some homework & talking to the local tuner turned me to the TTS.
Colin
Feb 14/1994-Nov 29 2012
Rest in Peace sweetheart.
Colin1966 is offline
post #19 of 20 (permalink) Old 10-12-2012, 07:03 AM
qkshift's Avatar
I used the seracetuner you dont need to instal it for the mods your doing until you change your cams dealer can flash your ecm with a stage one common download most dealers charge around a 100$ for it when your cams or installed a dyno tuned with the race tuner will work great
qkshift is offline
post #20 of 20 (permalink) Old 11-04-2012, 03:03 AM
mitchdm's Avatar
I think the warranty issue is being overstated. I have had 30hd's with multiple mods ~ never had a warranty claim denied, or extended warranty claim.
06 SE Ultra PCV with autotune ~ new rear head at 40 & 80k Traded the bike at 93k ~ new owner utilized the extended
10 Ultra LTD with PCV & autotune ~ New rear head at 30k
60k new camplate/cams/oilpump, on the fourth compensator, in the boutique now having a stator replaced ~ under the extended selling the bike now ~
Both of these previous bikes were mildly built ~ the 10 with the 103 dyno'd at 110/114 ~ it is all about the dealer/indy.
Most folks don't know that some indys are authorized to do work under the extended also.
I always buy the extended ~ my current FLTRXSE has a dealer installed stage III with SEPST FM 2/1/2 ceramic, hd performance baffles, 259e's ~ I am not even the concerned about warranty/extended.
Can Harley Deny the warranty? Absolutely ~ you didn't have your oil changes completed by the dealer ~ the services were not done by the dealer.... Do I concern myself ~ no ~ not once with 30 HD's and 170k + on 2 ultras since 06, and over 5k in 6 weeks on the 12 RG have I had a single warranty/extended denied or questioned.
My .02
mitchdm is offline
