News Cams = new tune? - Road Glide Forums
post #1 of 12 (permalink) Old 10-20-2012, 10:39 PM Thread Starter
GlideShark's Avatar
Ok, now I am confused. Thought I had to re tune with cam swap but bunch of mechanics i ran into today said no. What do you guys think? Thanks
GlideShark is offline
post #2 of 12 (permalink) Old 10-21-2012, 10:05 AM
tmd
Its kind of a loaded question and depends on the cam. If its not much differernt then stock it will run fine. Will it be optimally tuned?: NO.
tmd is offline
post #3 of 12 (permalink) Old 10-21-2012, 12:25 PM Thread Starter
GlideShark's Avatar
SE 255. Thanks.
post #4 of 12 (permalink) Old 10-21-2012, 01:13 PM
The answer is yes regardless of the cam
spokanebagfan is offline
post #5 of 12 (permalink) Old 10-21-2012, 07:21 PM
LL Cool K's Avatar
+1 I agree
2012 FLTRU, Vance & Hines Power Duals, Fuel Moto Jackpot 4" Slash Ups and Air Filter, Power Vision
LL Cool K is offline
post #6 of 12 (permalink) Old 11-11-2012, 05:40 AM
Taccone's Avatar
To give you an idea, I have SE254E cam's in my bike, along with full exhaust and the SE heavy breather intake. I also have the race tuner with the download that is ment for the open'd up air and exhaust combo. Now with the cam's added which are a tad racier than the 255's the bike run's ok. Smooth most of the time and fuel mileage is still near stock, but it does "hiccup" often on light throttle take offs and at idles it will "hiccup" nearly stalling the bike every now and then. Def. going to get this dyno tuned to make her run properly and squeek out a few more ponies too! So yeah if you change anything around in the motor, heads, cam's, bore kit, full exhaust and intake it's wise to get it tuned so it runs properly. If not you could cause damage mainly to your new exhaust pipes with blueing or yellowing from running to rich or worse yet having the motor run even more lean!
Taccone is offline
post #7 of 12 (permalink) Old 11-11-2012, 06:54 AM
4getNo1's Avatar
Not enough info... what did you change from?
Personally, I don't think any cam change that's so minimal that no re-tune is necessary means that the cam change itself is so minimal that there will be no noticeable performance change either.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #8 of 12 (permalink) Old 11-11-2012, 09:24 AM Thread Starter
GlideShark's Avatar
Thanks for info guys but I got rid of the RGC. I appreciate the help.
post #9 of 12 (permalink) Old 11-11-2012, 09:55 AM
What did you replace the RG with?
post #10 of 12 (permalink) Old 11-20-2012, 08:09 PM
interesting......verrrrrrry interesting
MidLifeCrisisNC is offline
