Need Advise from the EXPERTS!!! - Road Glide Forums
post #1 of 4 (permalink) Old 11-05-2012, 06:42 PM Thread Starter
hamer007's Avatar
Here is the simple set up 2012 RGU, Stock Header with CAT Removed and Vance & Hines Twin Slash Cut Rounds Slip -ons. Am getting pinging and feels choked. The only other Mod I plan to do is go to High Flow A/C. What do you guys think the best Fuel Mngmt System for my set up would be without overkill. Only want my bike running with optimum mid Torque for 2 up riding. Was looking into the PowerVision????? Overkill or not ???? Or will FuelPak do the Trick????
2012 RGU Black,8 inch Klockwerks windshield,
Power Commander V,Vance&Hines Power Duals w/ high Outputs, Screaming Eagle High flow A/C,
PYO 10 inch Monkee Bars and alot of Wille G Skulls
hamer007 is offline
post #2 of 4 (permalink) Old 11-05-2012, 07:27 PM
Triplej's Avatar
While the Fuelpak works for some there is so much more you can do with the PV that it is hard to beat. One item which you are already concerned with is pinging. The Fuelpak does not allow for changes to the Ignition Timing if that is whats needed to tame your pinging issue.
Do a search on the PV and you will have hours of good reading and happy users telling of their experience with it. Maybe worth call to Fuel-Moto to discuss before making your purchase.
I have used the PCV, the EJK Unit by Dobeck and now the PV, hands down the PV is my choice. But for the record, I am by no means an expert on the subject, just giving my 2 cents worth.
Triplej is offline
post #3 of 4 (permalink) Old 11-05-2012, 08:55 PM
Boogitybob's Avatar
Smile
While I now have the Power Vision because I intend more engine mods I did have Fuelpak on my last FLTRU with dresser duals,monster ovals and a hf air filter I never had any issues with pinging the only problem I had with original numbers from Vance and Hines was a slight hesitation off idle. The bike ran great lots of power and got 40-42 mpg @70mph two up
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #4 of 4 (permalink) Old 11-07-2012, 07:53 AM
I have the same setup you have and tried all the tricks to get rid of the pinging,
removed the cat, inline enrichment devices, etc.I finally broke down and installed a PV. This cured all the problems ,no ping, better throttle response ,the bike runs cooler and doesn't go into parade mod while driving in traffic as often.
this also divorces you from the dealer and will allow you to do future upgrades .
shelton is offline
