Tuner question - Road Glide Forums
post #1 of 5 (permalink) Old 11-07-2012, 10:42 AM Thread Starter
Dmize's Avatar
Tuner question
Currently I'm running:
- Screaming eagle perf tuner (installed by dealer as a package)
- Stock 2:1 w/ SE Night Stick muffler
- SE Heavy Breather
I'm thinking about picking up a set of Rush True Duals (from a member) and a different Air intake (due to getting lowers).
I guess I'm not certain if the SE tuner is as programmable as some of the aftermarket (and more popular ones). I've read about people being able to just go into the software and use pick lists with new items they've installed and then downloading the appropriate tune....Will the HD version do this as well?
Thanks in advance for input.
D.
D.Mize
16 CVO RGU
Dmize is offline
post #2 of 5 (permalink) Old 11-07-2012, 02:38 PM
Hullhorr's Avatar
Dan, I don't know alot about the SE Tuner, but you can download different maps to it from HD when you make changes. I would bet the only maps they have though are for changes you make using HD parts. I'm just guessing on that one though.
2009 FLTR MOP
Hullhorr is offline
post #3 of 5 (permalink) Old 11-07-2012, 02:56 PM
josephthreedogs's Avatar
Once you learn how to use the SERT it is the most tunable tuner available. It is not the easiest to use but I belive it is the best one available.
josephthreedogs is offline
post #4 of 5 (permalink) Old 11-07-2012, 03:02 PM
Still Grumpy's Avatar
and if you're interested in selling the S/E intake let me know... ...
Still Grumpy is offline
post #5 of 5 (permalink) Old 11-07-2012, 03:11 PM
CNMTurner's Avatar
Here's a link that might help explain the SERT more for you..
Hope this helps..
http://www.bigboyzcycles.com/showthread.php?t=93
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
