How do i tell which map - Road Glide Forums
post #1 of 2 (permalink) Old 11-22-2012, 12:01 AM Thread Starter
Still stuck on the pcv
I dont see how to tell what map is loaded on the pcv , jamie wont be open till monday
Here is a pic of the screen the only way i can get a look at the values is to click on fuel , is that right ? ImageUploadedByMotorcycle1353560100.190905.jpgImageUploadedByMotorcycle1353560112.186882.jpg
Also their is a pic of the map file , i named one of them rinehart and had to drag and drop the 2 into 1 map into the file
I have pretty much messed it up it looks like i cant tell what map was preloaded from fuel moto
The one in the map file that says rinehart slip ons says at the bottom
Rinehart mufflers stage one AC custom by fuel moto map version 299
The 2 into 1 map says custom by fuel moto map version 299
Any help would be great
Sent from my iPhone using Motorcycle.com App
2008 RG anniversary
You can teach a idiot , But you can't teach them much
08gezzer is offline
post #2 of 2 (permalink) Old 11-22-2012, 02:06 PM
RoadGlideGary's Avatar
Pcv
Your PCV will only hold one map unless you have a switch. Use the "get" map function - that is the map on the pcv. It should show the name. PVC software saves your maps in its directory on your computer hard drive so you won't loose them.
Unless you are running an auto tune you can't see the AFR - all you can see or modify is the fuel table - which is the amount of fuel added or removed based on a dyno map to match the afrs.
05' SuperGlideCustom - sold
RoadGlideGary is offline
