boy , i feel dumb - Road Glide Forums
post #1 of 4 (permalink) Old 11-22-2012, 08:43 AM Thread Starter
boy , i feel dumb
I dont know what i did , but i installed my PCV and the bike wouldn't start , 02 sensors where unhooked , had the key fob in my pocket , unhooked PCV and bike fired up , Not sure if i lost the program on the PCV or not I shouldnt have messed with trying to load a different map
2008 RG anniversary
You can teach a idiot , But you can't teach them much
08gezzer is offline
post #2 of 4 (permalink) Old 11-22-2012, 12:59 PM
RoadGlideGary's Avatar
pcv
If you had it connected correctly and the O2 caps on (they only fit one way) and it would not fire up I would say you probably messed up with the new map. Check the connector pins to be sure the are straight. If you use the "get" map it retrieves the map on the pcv. If you want to load a new map use the "open" to find the new map, click on it and then use the "send" function to send it to the pcv. Try again. Don't worry about the Pcv you can't screw it up - anything you do can be undone.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 4 (permalink) Old 11-22-2012, 03:26 PM Thread Starter
I'm going out to try it again , Thanks for the info
2008 RG anniversary
08gezzer is offline
post #4 of 4 (permalink) Old 11-22-2012, 04:41 PM Thread Starter
Well , i am as dumb as i look , that did it , works great now, i removed the map and didnt put one back in it ,both maps worked, once i followed your directions on how to load it
Thanks for the help , happy turkey day
Sent from my iPhone using Motorcycle.com App
2008 RG anniversary
08gezzer is offline
