Pcv trouble - Road Glide Forums
post #1 of 4 (permalink) Old 11-25-2012, 07:55 AM Thread Starter
Pcv trouble
Ok, had engine light codes u106,p0120,p0220,p0222,p0373,p1510 & p1511
Cleared codes bike wouldnt start , disconected pcv bike started no codes ?
Might send pcv back and try and talk the boss into a power vision instead
Any one think its a pcv problem ?
Sent from my iPhone using Motorcycle.com App
2008 RG anniversary
You can teach a idiot , But you can't teach them much
08gezzer is offline
post #2 of 4 (permalink) Old 11-25-2012, 07:59 AM Thread Starter
Also any idea what a pv costs for a 08 from fuelmoto
2008 RG anniversary
08gezzer is offline
post #3 of 4 (permalink) Old 12-01-2012, 06:48 AM
Eshaw301's Avatar
Dont sound like a bad pc just sounds like a loose connection. I would try to reconnect and make sure all is snug and tight. Also, did you disconnect the oxygen sensors BEFORE you started the bike? That will cause issues and wont allow it to start. It says to do that in the instructions. Also, did you have a fuel map installed on the pc?
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #4 of 4 (permalink) Old 12-01-2012, 06:50 AM
Eshaw301's Avatar
Probably $500
Eshaw301 is offline
