What makes the bike run cooler? - Page 2 - Road Glide Forums
post #11 of 16 (permalink) Old 11-27-2012, 07:20 PM
Bandit 7's Avatar
As others have said get rid of the CAT, it is made of ceramicand holds the heat in.
Bandit 7 is offline
post #12 of 16 (permalink) Old 11-27-2012, 07:34 PM
Flexin's Avatar
There are three places that slow down the flow of air. The new pipes may help it breath easier on the back end, you now have two remaining places slowing down airflow, the air filter and the cat in the head pipes.
If you want you can keep the stock mufflers, like the rest have said, cut out the cat. A new filter and turner (with the right map) will cool things down.
Flexin is offline
post #13 of 16 (permalink) Old 11-27-2012, 10:20 PM Thread Starter
Well, after seeing my buddy pulling into our condo garage with a road king without cats changed my mind. It is loud as hell in the garage. It makes so much noise just pulling in, sets alarms off in a chain reaction.
I guess, I could buy his headers very cheap I wanted to move! )
So, he is going back to stock headers and I am staying stock !
I hope changing the air filter to high velocity will help the heat issue.
I am so confused!
Should I still get the sert pro kit or the download from the dealer? Considering, there will be no headers in the future!! (
By the way, here is a picture of my rc slip-ons. I love them.
O-town is offline
post #14 of 16 (permalink) Old 11-27-2012, 11:04 PM
Bandit 7's Avatar
I am so confused!
Ultimatly it is your choice on how you go with exhaust but your major heat issue is the CAT. There are several header/muffler combos that are not too loud but give a good low rumble. I have the V&H power duals with V&H monster rounds for mufflers. It took care of all the heat issues and is not that loud. I know loud because my 94 Heritage is extremly loud. The V&H web site has videos of the exact exhaust I have and I know there are other makes that have the same. IMO the air filter is not going to make much difference for the heat issues in the exhaust . You should check around and listen to others bikes with different header/muffler combos before you decide not to change yours.
Bandit 7 is offline
post #15 of 16 (permalink) Old 11-28-2012, 03:14 AM
Andyman's Avatar
Try twisting the throttle a little harder. : )
'03 Deuce: 90k miles and counting, '11 RGU: 80k miles and counting.
Andyman is offline
post #16 of 16 (permalink) Old 11-29-2012, 08:26 AM
smitty901's Avatar
30 degree weather. Come on how much difference is a little fuel really going to make for more than a short time.
Think skills vs hype
A good total stage 1 will help not magic but some what effective.
smitty901 is offline
