Adjusting shifter... - Page 2 - Road Glide Forums
post #11 of 15 (permalink) Old 10-28-2012, 09:15 PM
idahointrudr's Avatar
Originally Posted by bucketlisthd View Post
I recently stripped the front shift lever 60 miles from home on back roads. (lotsa shifting) I managed to get home using the rear lever for both up & down shifts.
Woulda been tough with only one lever. I use the rear lever exclusively for upshifts anyhow, so it's stayin'.
Thats good info. I could never get used to using mine ,on any of my bikes.
I wonder if you could put the rear shifter up front. Reverse the pedal part. If thats the case I would throw the rear in the saddle bag. That way I would have a back up?
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #12 of 15 (permalink) Old 10-29-2012, 03:25 AM
front and rear shifters are the same part .I took em both off and compared.I used the kuryakyn spacer and moved the front one outboard.
danglide is offline
post #13 of 15 (permalink) Old 10-29-2012, 07:47 AM
bucketlisthd's Avatar
Yup, same part front & rear. Alot of folks don't like the rear shifter. Personally, it's all I use for up-shifts.
Those bolts are tight! I used a 3/8 drive allen gizmo & a 1/2 drive adaptor on a 1/2" ratchet. That did it. I was on a mission as the front lever was completely stripped. It was coming off one way or the other.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #14 of 15 (permalink) Old 10-29-2012, 10:22 PM
Good to know. Thanks
post #15 of 15 (permalink) Old 11-14-2012, 12:02 AM Thread Starter
bikerglasses's Avatar
Adjusted mine and much better, actually alot easier to find neutral now. I haven't started using the heel toe shifting.. we'll see..
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, pcV
bikerglasses is offline
