LED turn signals - Road Glide Forums
post #1 of 7 (permalink) Old 04-10-2012, 07:46 PM Thread Starter
Ditch's Avatar
LED turn signals
Just installed my Custom Dynamics Dynamic Ringz Driving Lights & Turn Signals.
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
post #2 of 7 (permalink) Old 04-10-2012, 08:08 PM
Jetman's Avatar
Nice........did you have to install an equalizer as well or no?
If you don't mind, can you share the part #'s from CD?
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #3 of 7 (permalink) Old 04-10-2012, 08:56 PM Thread Starter
Ditch's Avatar
I did the kit GEN200AW-KIT witch is front and back and a load eq. and smoked lenses you have a choice of lenses and colored of lights. it took about 10 min to instal the load eq needs a power and a ground.
Zummo 665
HD Air deflectors
Sancho's wings
cup holder
Power Vision
Ditch is offline
post #4 of 7 (permalink) Old 04-10-2012, 09:02 PM
Jetman's Avatar
Thanks..........
Jetman is offline
post #5 of 7 (permalink) Old 04-10-2012, 09:10 PM
Easyryder01's Avatar
If you have a pic of the load equalizer please post.....I have the same lights and lenses and the load equalizer as well but I didn't have to do a ground and positive line to it. The only thing I was told was that if I decided to change my head unit and or add an amplifier I would need to cut a certain wire and install the included fused line. Other than that it was all plug and play. Is yours half the size of a candy bar but just as thin and grey? I originally had the kuryakyn 2 piece unit and nothing but problems with heat and malfunction. Kuryakyn also had mentioned that they use 2 different ones because I had the factory alarm. Don't know if that's the case with Custom Dynamics unit.
2017 RGS Velocity Red
Easyryder01 is offline
post #6 of 7 (permalink) Old 04-11-2012, 06:12 PM Thread Starter
Ditch's Avatar
mine is blue and about the size of a candy bar around 6, 1.5, .5 in
Zummo 665
HD Air deflectors
Sancho's wings
cup holder
Power Vision
Ditch is offline
post #7 of 7 (permalink) Old 04-11-2012, 06:16 PM
HarleyLance's Avatar
I think that's the Signal Stabilizer, which is what I have as well. It has both a power and ground. I was told that unit is compatible with the security system (i.e. it doesn't make the indicator light go on), and should not interfere with upgraded amps.
Ditch, your lights look great!
2010 Road Glide Custom FLTRX Scarlet Red - SE Stage 1 AC, Carriage Works Tornado Slip-on, SE SuperTuner, Jagg Fan Assisted Oil Cooler, 12" Windvest, HD Chrome Saddlebag Guards, Arc Audio MPAK 6
HarleyLance is offline
