FLTRX tail lights - Road Glide Forums
post #1 of 4 (permalink) Old 08-16-2012, 09:17 PM Thread Starter
mmcmsw's Avatar
FLTRX tail lights
Okay, On my 2011 RGC, I am trying to powder coat the rear tail light. I have the wires out, with the exception of the ground (black) wire still sitting in the reflector. I have been known to break stuff, so If there is an easy way to pull this connector out of the reflector, let me know. Thanks.
EDIT: I have looked at this, and I have two other options. Disassemble the deutcsh plug. (PIA) Cut, solder and heat shrink the wire harness.
Trailers are for Boats!!
mmcmsw is offline
post #2 of 4 (permalink) Old 08-17-2012, 07:56 AM Thread Starter
mmcmsw's Avatar
any Ideas
any ideas???
mmcmsw is offline
post #3 of 4 (permalink) Old 08-17-2012, 08:00 AM
i did cut and solder. i avoid solder if i can but it was the most direct option
dirt.bagger.11 is offline
post #4 of 4 (permalink) Old 08-17-2012, 08:10 AM
HD_Shock's Avatar
Those ground wires were the same reason I cut and soldered. There might be another way but cutting seemed a whole lot easier than disassembling the deutcsh plug. I wanted the solder joints inside the housings but there's not much wire to work with ... I made the cut rougly 3/4 in. into the housings and soldered extensions onto the wires before I reassembled to give some room.
Here's where I made my cuts ...
-phil
2011 FLTRX 103
HD_Shock is offline
