Hi all
We have an 11' Road Glide Ultra CVO and already have the Custom Dynamics LED white with Amber turns on the front
Now I'm looking to convert our rear tourpack to "run brake and flash"
Anyone do it, what was needed? Works like a charm?
I like your bike and the color. Going to subscribe to this thread. My tour pack the center lights with the brakes but would like the left and right corner to work as signals too
I also have the same 11 red CVO. I made the turn signals a red run/brake/turn and then added the Led run/brake/turn under the saddle bag. Kid says in the daylight it looks like a fire truck when I hit the brake at almost a 1/4 mile.
On the CVO forum they have a thread on how to make the sides turn signals.
Not a hunert percent sure if it's different for the CVO, but if you have a run turn brake module for your rear turn signals then there is a small wiring harness that you can plug in after the module that will add that function to your tour pak. I believe it also makes the side lights work as turn signals.
I'd give Custom Dynamics a call,,, They are extremely knowledgeable about the differences of the years, models, etc... Or you could check out CVO Harley,, they pretty much know what they're doing,,, a Great bunch of folks...
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
