Sorry, I'm no longer building these kits anymore.
Complete LED kit for your Touring Machine
$150.00. No Cutting, No Splicing. Just Plug and Play.
Offering a Single Color LED Kit that is specifically catered to the Harley-Davidson Touring models
Features:
-Color: Red, Blue, Green, White, Yellow, Purple (+ $24.99 - Ultraviolet)
-No splicing
-No cutting
-Peel & Stick
-1 to less than a 2 HR install
-Detailed instructions with photos
-If a strip goes out, I'll repair or replace it
Tools Needed
-8mm wrench (and that's only for the toggle switch nut), wire cutter (to cut end off of zip tie), Torx socket or screw (to remove battery cover) & rubbing alcohol.
Led Locations:
-Front Fender
-Rear Fender
-Gas Tank
-Lower Frame
-Beneath saddlebags
-Beneath seat (mid frame)
Normally an L.E.D. kit you purchase now is not bike specific and is probably why you are turned off on buying or installing one. It's just plain annoying. I've installed a ton of L.E.D.'s on many bikes, but have always been those kits you see. The one I'm offering is by far the easiest and most rewarding.
L.E.D Touring Bike Specific pricing:
Base Kit: $150.00 shipped to your door
Includes 1 color for all sections aforementioned above with a toggle switch
Optional H-D accessory plug & play connector: $19.99 (2014 & earlier)
Use the accessory switch on your panel (True plug & play to access power).
Eliminate the battery cover removal and using exposed terminals to power.
(Please note: this option works when ignition switch is set to "on" or "acc" and accessory switch is on.)
Here are some pictures of the kit installed on my personal Road Glide
Features:
-No splicing
-No cutting
-Peel & Stick
Tools Needed
Led Locations:
-Front Fender
-Rear Fender
-Gas Tank
-Lower Frame
-Beneath saddlebags
