Ignition Question - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 23 (permalink) Old 01-23-2012, 02:52 PM Thread Starter
BlackDangerous's Avatar
Ignition Question
I am building a fairy stout 98" engine for my Glide. I have been looking into the Daytona Twin Tech ignition but I do not want to spend the amount of money that they are asking for them. Is changing the ignition a "MUST DO" or can I get by with the factory ignition?
BlackDangerous is offline
post #2 of 23 (permalink) Old 01-23-2012, 04:17 PM
Engine Expert
DragoBikeWorks's Avatar
Help us understand what kind of build.....
Thanks
FD
When Others Promise Power We make it Happen. Quality-Performance-Respect-Drago's Bike Works 815-765-1790
DragoBikeWorks is offline
post #3 of 23 (permalink) Old 01-23-2012, 08:27 PM Thread Starter
98"
Red Shift .557 cams
Good Street Head Port with Bigger valves
New Bearings (Cam)
40mm CV carb
About 9.3:1 Corrected compression
post #4 of 23 (permalink) Old 01-23-2012, 08:30 PM
I'd call that more than "Fairy Stout".
Sorry, Bro.
FGOWI is offline
post #5 of 23 (permalink) Old 01-23-2012, 08:37 PM Thread Starter
First time going this far into my Glide. It should give me over 100/100, but the torque is what I am shooting for the most.
post #6 of 23 (permalink) Old 01-23-2012, 10:11 PM
no way to tell but the stock ecm has a fairly aggressive timing curve on 88" baggers. Not sure what year yours is but if it is a carb and you are going 98" it must be a pre 07. My 04 95" egc that had mild head work and mild cam needed a dtt adjustable ignition for optimum performance.
jeff is offline
post #7 of 23 (permalink) Old 01-23-2012, 10:48 PM Thread Starter
Yep, my Glide is an 01 so it has the carb. I was able to lock the price down pretty good for the ignition. Do you think that $200 is a bad price for brand spaken new ignition?
post #8 of 23 (permalink) Old 01-23-2012, 11:08 PM
what brand? if it is a daytona twin tech that is a good price. I paid something like $225 in 2005 or so. You will then need the software and cables to give it a custon map unless it runs good with the standard dial settings. DTT and headquarters are the same unit as I believe crane is as well. S&S made a neat one back then that had a knock sensor that it would autmatically adjust the timing. i think it was called IST or something like that but it was kind of spendy.
jeff is offline
post #9 of 23 (permalink) Old 01-23-2012, 11:16 PM Thread Starter
Yes it is a Daytona Twin Tech ignition. I am trying to get what it is that I need as cheep as I can as I want to buy a set of pipes from Drago. A friend of mine has a really cool toy from DTT. It is to measure the AFR. I think that I am going to relieve him of that item.
post #10 of 23 (permalink) Old 01-24-2012, 09:55 AM
Engine Expert
Daytona makes nice stuff I would reccccc. more control you have the better tuning you can have. We are a dealer for them if you have any questions calls or them.
