CVO 110 Performance Upgrade - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 45 (permalink) Old 02-07-2012, 09:25 PM Thread Starter
smitty2u's Avatar
This is my first post to the general forum. I have a 2011 FLTRUSE which I initially just want to do pipes, slipons, tuner, and a good Dyno. It seems for me, that scooter projects always morph and this was no exception. What started as a slight modification has turned out to be something quite different. Here's the build that's underway:
Head sent off to be done by T-Mann, his Pro Touring Version
T-Mann 625 Cam
SE 10.5:1 forged pistons
4-5/8" stroke Se Pro Stroker Flywheel and rod Assembly, balanced and welded by Revolution Performance
Timekin Bearing
SE 58mm TB
SE 5.3 grms/sec injectors
SE Pro tuner.
Woods lifters,
SE rods
SE Clutch upgrade
Andrews 31T sprocket
V&H Power Dual headers and V&H 4" Monster Round mufflers.
Staying with the stock breather cover, but switching to a K&N filter.
Last but not least, would be a good Dyno.
My scooter has been at my local dealer, (Buckminns in Xenia Ohio) for a couple weeks. Heads are due back this week and then reassembly begins.
If anyone is interested I'll post the Dyno results when she's finished.
Smitty
smitty2u is offline
post #2 of 45 (permalink) Old 02-07-2012, 10:02 PM
FLTR2008Trike's Avatar
I had TR @ Tman do his quality work to help me build my 117" 2 years ago. Hes very meticulous about his work and his shop is spotless. You will be very happy with your results
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #3 of 45 (permalink) Old 02-07-2012, 10:04 PM
connector's Avatar
Wow that really Morphed on you I like the idea though .Do it once ,do it right . I'm curios as to how this set up works for you , just changing out my cam ( T-Man 590 ) so post up your results..This should be good
09 FLTR 103 Stage III
connector is offline
post #4 of 45 (permalink) Old 02-08-2012, 06:17 AM
DreamRider's Avatar
Look forward to seeing the outcome. Maybe post some pics of before and after
DreamRider
RoadGlide FLTRXSE CVO 12' - Cobalt Blue -
DreamRider is offline
post #5 of 45 (permalink) Old 02-08-2012, 08:01 AM
Engine Expert
DragoBikeWorks's Avatar
You will have a nice build there you will be happy... Cant wait to see.
Originally Posted by smitty2u View Post
This is my first post to the general forum. I have a 2011 FLTRUSE which I initially just want to do pipes, slipons, tuner, and a good Dyno. It seems for me, that scooter projects always morph once their started and this was no exception. What was started as a slight modification has turned out to be something quite different. Here's the build that's underway:
Head sent of to be done by T-Mann, his Pro Touring Version
T-Mann 625 Cam
Timekin Bearing
SE 58mm TB
SE Pro tuner.
Woods lifters,
SE rods
SE Clutch upgrade
V&H Power Dual headers and V&H 4" Monster Round mufflers.Staying with the stock breather cover, but switching to a K&N filter.
Smitty
When Others Promise Power We make it Happen. Quality-Performance-Respect-Drago's Bike Works 815-765-1790
DragoBikeWorks is offline
post #6 of 45 (permalink) Old 02-08-2012, 09:29 AM
Rowdy's Avatar
I'd say it morphed... I am subscribed, very interested in the numbers it produces.
Rowdy
Rowdy is offline
post #7 of 45 (permalink) Old 02-08-2012, 11:20 AM Thread Starter
smitty2u's Avatar
Here's a few pictures of the beginnings of the project. Will post more, probably next week.
Smitty
2011 FLTRUSE
124HP 130TQ
TR Stage 2 Street Eliminator Pro-Touring Heads
TR 660-SM Cam
TTS Master Tuner
Cylinders 4.060 Bore
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
V&H Power Dual headers with V&H Twin Slash Round Slipons
K&N air filter
Andrews 31T transmission sprocket
smitty2u is offline
post #8 of 45 (permalink) Old 02-08-2012, 04:22 PM Thread Starter
smitty2u's Avatar
The "Do it once" idea is how this all evolved. I didn't want to have to pay twice for labor and another dyno. I figured it was cheaper in the long run to build it the way I wanted it, the first time.
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
smitty2u is offline
post #9 of 45 (permalink) Old 02-17-2012, 07:58 PM Thread Starter
smitty2u's Avatar
Well the bottom is back together. We've changed a few things as well. Going with the TTS Mastertune, TR-660-SM cam, cylinder bored to 4.06.
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
smitty2u is offline
post #10 of 45 (permalink) Old 02-17-2012, 07:59 PM Thread Starter
smitty2u's Avatar
Can't wait to hear her run.....
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
smitty2u is offline
