Cam choice - Page 2 - Road Glide Forums
Sponsored by Drago's Bike Works
post #11 of 45 (permalink) Old 03-26-2012, 02:59 PM
Unless your going to up the comp. ratio, I'd put the 48's in and call it done.
2010 Vivid Black Road Glide Custom
Mike Jesse is offline
post #12 of 45 (permalink) Old 03-27-2012, 07:12 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
Originally Posted by craigv65 View Post
I would like to know about the 570? I can get a sweet deal on them.
They work as described via S&S, but do want 10-10.2 cr to show their teeth.
We are currently doing a build with those in an 2003 Dyna.
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
post #13 of 45 (permalink) Old 03-27-2012, 08:39 PM
take a look at the wood TW5-6 for torque down low.
kevdon is offline
post #14 of 45 (permalink) Old 03-27-2012, 08:56 PM
I recently had a set of S&S 570s installed in my bike, I have a 107 build with Rev Performance jugs, I'm still breaking the build in, but so far I like the cam. I don't know when I'll have it dynoed to show exact numbers but the cam seems to start pulling around 2.7-2.8k, and I don't know where it stops yet.
post #15 of 45 (permalink) Old 03-28-2012, 01:37 PM
Engine Expert
Yep, that'll also get-r-done, but 10.0 cr is needed.
Scott
5225 SOUTH MAIN ST.
post #16 of 45 (permalink) Old 03-28-2012, 03:00 PM Thread Starter
craigv65's Avatar
How about the andrews 54? May use a cometic .03 gasket.
2012 FLTRX
Roland Sands Design Contrast Cut line
Roland Sands Hang-Lo Seat
Roland Sands Glider Bars (TBD)
H-D Edge Cut line
FullSac X-Pipe B
CFR Exhaust (The BEST sounding I ever heard)
Tman TR-600sm cams
TTS Matertune
J&M 7.25 Rokkers with 250 watt amp
Progressive Mono Tube Suspension
craigv65 is offline
post #17 of 45 (permalink) Old 03-28-2012, 03:29 PM
I think you would be pretty happy with the 54's and a little more compression. They will pull right up to 6000.
rc_chico is offline
post #18 of 45 (permalink) Old 03-28-2012, 05:23 PM
I agree. Gotta add some cylinder pressure to get the most out of them.
Those 48's look better all the time. Pretty cheap too from Direct Harley Parts.
post #19 of 45 (permalink) Old 03-29-2012, 11:26 PM Thread Starter
craigv65's Avatar
Really undecided wether to get the 48 or 54?
2012 FLTRX
H-D Edge Cut line
FullSac X-Pipe B
Tman TR-600sm cams
TTS Matertune
craigv65 is offline
post #20 of 45 (permalink) Old 03-29-2012, 11:28 PM Thread Starter
craigv65's Avatar
Anybody have a good tts map for either?
2012 FLTRX
H-D Edge Cut line
FullSac X-Pipe B
Tman TR-600sm cams
TTS Matertune
craigv65 is offline
