Cam suggestions - Road Glide Forums
post #1 of 44 (permalink) Old 08-09-2012, 05:44 PM Thread Starter
Cam suggestions
I have an 11 RGU with nightsticks, stage 1, de-chatted, Cobra Fi2000 tuner and am looking for cams, Ride 10-12k per year, Almost always 2up, 425lbs combined weight. Could be talked into pipes as I am not in love with nightsticks and not sure of the advantages of de-chatted vs true header. Looking for 40-70 mph power curve. Anyone have input.
1976 Kawasaki KZ900
86 road glide(cream n crap)
97 EG ultra(frank)
98 Heritage Springer(Bruiser)
03 EG Standard(Blackie)
2011 RGU Big Blue Pearl blacked out(Papa Smurf)
maddogdrury is offline
post #2 of 44 (permalink) Old 08-09-2012, 06:04 PM
prodrag1320
Guest
Posts: n/a
if your doing a "cam only" change (ie:no compresssion or headwork)ide look @ the andrews 37
post #3 of 44 (permalink) Old 08-09-2012, 11:41 PM
HarleyJack's Avatar
S&S 551
JtB
2011 Ultra
HarleyJack is offline
post #4 of 44 (permalink) Old 08-10-2012, 06:02 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
Wood 222.
You'll be AMAZED!!!
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
post #5 of 44 (permalink) Old 08-10-2012, 09:11 AM
tdkkart's Avatar
I've got the SE204 in mine, works well. IMO 6th gear was useless at 60mph before, now it's quite useable, the bike will actually accelerate when you turn the throttle when cruising in 6th. Probably added 10mph of useable range to 6th gear, and added quite a bit of mid range pull when running through the gears. The intake closing number makes it drop a bit of cranking compression, which helps reduce pinging also.
I used the Andrews 37 in my 2 previous bikes, but wouldn't use it without bumping the compression up a bit first. The later(later than the 204) intake close drops a bit too much compression for a stock motor IMO.
I have no experience with the S&S or Woods cams, but the numbers on the 222 do look good.
tdkkart is offline
post #6 of 44 (permalink) Old 08-10-2012, 12:19 PM
Smile
Scott, how do you like the new Woods TW-222 cam compared to the new Andrews 57H cam.
rgbikeman is offline
post #7 of 44 (permalink) Old 08-10-2012, 12:50 PM
he said looking for 40-70mph increase with 425 lbs of weight. se255 or andrews 48 would fit the bill
jeff is offline
post #8 of 44 (permalink) Old 08-10-2012, 09:18 PM
There are so many good cams out there that fit the bill.
Tman 555 tq
Cycle rama 575
Andrews 57 new
S&S 551
Tman 600 sm
Woods 222 new
Zippers 525 cams new
But adding cams is like getting a tattoo you will want more.
All those cams up above will work. At my shop we favor Tman cams.
We have done builds for stock 103 tman 555tq with a good exhaust and tune and have seen 98 hp 110 tq.! With good port job we have seen 105/110 hp and 118/125 tq. With out building high compression motor. Just make sure you pick the right cam that can grow with your build.
Thanks
FD......
DragoBikeWorks is offline
post #9 of 44 (permalink) Old 08-13-2012, 06:30 AM
Engine Expert
Have not seen back/back comparisons as of yet.
Scott
5225 SOUTH MAIN ST.
post #10 of 44 (permalink) Old 08-13-2012, 05:13 PM
RoadGlideGary's Avatar
Exclamation Cams
If you have extra $$$ buy the new designer cams, if you don't have the extra $$$ consider the tried and true - SE or Andrews. There is always something newer and hotter, so they say, but it it is reliability you want. Andrews makes a lot of cams under their name and for others - that should tell you something.
05' SuperGlideCustom - sold
RoadGlideGary is offline
