107 - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 10 (permalink) Old 11-03-2012, 08:47 PM Thread Starter
107
can anyone tell me if i change my pistons which is 10to1 to 10.5to1 will it give engine a noticable diffence in power an will it make engine run hotter (put out more heat)
hardrock is offline
post #2 of 10 (permalink) Old 11-07-2012, 06:39 AM
prodrag1320
Guest
Posts: n/a
sure it will make more power,but youve got to make sure your cam will support the added compression,as far as heat goes,once again if your cam isnt right for the added compression,yes it`ll run hotter (make sure your tune is right too)
post #3 of 10 (permalink) Old 11-07-2012, 06:39 PM
What is your current engine build? More horsepower = more heat, heat is power.
rc_chico is offline
post #4 of 10 (permalink) Old 11-07-2012, 08:59 PM Thread Starter
107
the build is a 107 575 mackey cam248 lift 248 duration revolution heads flowed an decked v&h power dualls with monster ovalls revoltion perf. fuel mang. 10to1 pistons power 91hp102tq not enough iwas going to put 30thous head gasket that would drop dn to 10.2to1 should help some an putting a 58mm tb on it also
hardrock is offline
post #5 of 10 (permalink) Old 11-08-2012, 05:14 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
If the intake closing event of that cam, is at 45* or a tick later, then 10.5 is OK.
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
post #6 of 10 (permalink) Old 11-08-2012, 05:25 AM
mitchdm's Avatar
Had a 107" in my Ultra ~ 10.5 to 1, then I had the heads decked (Blew a head gasket) no noticeable difference in heat, slight improvement in power ~ this could have been due to the gasket ~ .....
mitchdm is offline
post #7 of 10 (permalink) Old 11-08-2012, 01:06 PM
That cams intake closing is 42*, they recommend up to 10.2-1 compression ratio.
So you idea of a .030 head gasket would put you right where you ought to be. And is pretty cheap to do.
rc_chico is offline
post #8 of 10 (permalink) Old 11-08-2012, 08:17 PM Thread Starter
107
I bought a 55mm tb but sent it back wasnt right one got a 58mm i hope its not to big an motor can handle it , should i use stock injectors.or the big ones
hardrock is offline
post #9 of 10 (permalink) Old 11-08-2012, 09:10 PM
Stock injectors are good for 100 HP according to the HD catalog. You should be making way more than that.
rc_chico is offline
post #10 of 10 (permalink) Old 11-09-2012, 05:47 AM
Engine Expert
On an engine that carries a high VE, you'd be surprised how far an OE injector will go.
Scott
5225 SOUTH MAIN ST.
