2012 fltru stock cam numbers - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 12 (permalink) Old 11-14-2012, 08:23 AM Thread Starter
DOOFUS's Avatar
I looked but cannot find it on here -- does anyone know the numbers for our stock cam on the 2012 FLTRU? I'm trying to compare to the TW-222 regarding lift/duration etc. Thnx, DOOF
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #2 of 12 (permalink) Old 11-14-2012, 08:52 AM
tdkkart's Avatar
Check here:
http://bigboyzheadporting.com/tccams.htm
In the drop down select HD injected 07-09.
This came up on a forum a couple weeks ago, and nobody could come up with any newer numbers.
Pretty much the numbers could be labeled as "piss-poor".
tdkkart is offline
post #3 of 12 (permalink) Old 11-14-2012, 09:51 AM
Dickie's Avatar
You can also find them in the HD SE Parts catalog that can be downloaded from the HD website. Shows a numbers chart comparing a few SE cams too. I have the 204's in mine.
2011 FLTRU
Dickie is offline
post #4 of 12 (permalink) Old 11-14-2012, 11:06 AM
Tony G...PFFP's Avatar
cams
iv got a 20011 with the SE stage 2 big bore kit (103) i believe the same kit is on the 2012 (???) i have the spec sheet, its showing SE255...lift 556/556...duration 211/235...don't quote me though, HD should give u a motor parts list if u ask them.......PFFP
Tony G...PFFP is offline
post #5 of 12 (permalink) Old 11-14-2012, 01:44 PM Thread Starter
DOOFUS's Avatar
Thnx crew !
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #6 of 12 (permalink) Old 11-14-2012, 05:44 PM
rcpops53's Avatar
Thumbs down
Ok.....let me get this right....my 2011flhtru came w/255's and the Stealer, sold me 255's to hop up my new ride , before delivery ?
rcpops53 is offline
post #7 of 12 (permalink) Old 11-14-2012, 06:17 PM
panhead's Avatar
I dont believe the 103 come with the 255 cams..The 96 and 103 have the same cams (milder) from the factory. I am told the 110 Screamer Eagles do come from the factory with the 255s.
2011 COOL BLUE PEARL FLTRX , 120R,
too much to list...
panhead is offline
post #8 of 12 (permalink) Old 11-14-2012, 06:21 PM
Dickie's Avatar
No, CVO models only came with the 255's stock.
2011 FLTRU
Dickie is offline
post #9 of 12 (permalink) Old 11-14-2012, 07:35 PM
cams
my apologies i forgot to tell you i bought my bike with a 96" ....then did the upgrade...so the 103 kit comes w/SE255...like i said I'm not sure what the factory 103 came with...sorry if i messed you up..........
post #10 of 12 (permalink) Old 11-14-2012, 08:35 PM Thread Starter
DOOFUS's Avatar
Ok - I found the SE Catalog showing the stock 103 cam numbers:
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
