Exploring two options.......? - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 13 (permalink) Old 11-15-2012, 06:24 PM Thread Starter
Fire-Medic's Avatar
So "hypothetically" speaking, if you guys had two choose between the following for roughly the same cash which would you choose and why?
A) Upgrade your 103 with cams and headwork
B) Step up to a 107 kit that includes cams but no head work
There would obviously also be an upgrade to the stock exhaust, A/C, tuner, but that's going on no matter what.
Fire-Medic is offline
post #2 of 13 (permalink) Old 11-15-2012, 06:28 PM
JJSW1283's Avatar
I'd go ahead and do the 107 if it was me
JJSW1283 is offline
post #3 of 13 (permalink) Old 11-15-2012, 06:49 PM
4getNo1's Avatar
Personaly, I think a touring scoot benefits more by enhancing torque across a wide RPM band and I don't think you would need head work anyway if you went the "more torque" route (more displacement but still a modest RPM via a set of cams with some more lift but not a lot of duration). The "more HP" route ("sweet spot" is more narrow and at higher RPM via greater air-flow with cams that apply more extended duration) is great if you stay up there and use it but (again, personally) I don't run consistently at high RPM.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #4 of 13 (permalink) Old 11-15-2012, 07:21 PM Thread Starter
Fire-Medic's Avatar
Kinda what I was thinking and what got me looking at the 107 to begin with. Thanks for your input.
post #5 of 13 (permalink) Old 11-15-2012, 07:32 PM
direwolf's Avatar
Went with the 107 on my 2008 96 ci and never looked back, SE Heads ported & polished, 577 cam, Rev Perf auto tuner & Big Sucker Air Cleaner. Really woke it up.
2008 FLTR & 2009 FLTRSE3
direwolf is offline
post #6 of 13 (permalink) Old 11-15-2012, 08:45 PM
Hullhorr's Avatar
I just installed a 107", T-man 555tq cams, and Dragula 2-1 on my stock 96" and WOW what a difference. Already had a K&N filter and PC-V. going for the Dyno Tune in 150-miles to see what it's putting out, but so far very pleased with the difference. I did not do any head work.
2009 FLTR MOP
Hullhorr is offline
post #7 of 13 (permalink) Old 11-15-2012, 09:10 PM Thread Starter
Fire-Medic's Avatar
Would be very interested in your results, thanks for your input. That's one of the cams I am looking at.
post #8 of 13 (permalink) Old 11-15-2012, 09:11 PM
Where have you been hiding, and what happened to the Skunk? BTW, heads and jugs will probably cost close to the same amount, if I wanted high performance I'd probably go with the heads, but for everyday riding the jugs would do, jmo.
post #9 of 13 (permalink) Old 11-15-2012, 09:14 PM
TRUBlue's Avatar
Have heard it said many times: There's no replacement for displacement.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #10 of 13 (permalink) Old 11-15-2012, 10:47 PM
Hullhorr's Avatar
I'll be posting the dyno sheet when I get it done. Should be first or second week of December.
2009 FLTR MOP
Hullhorr is offline
