Stage 1 suggestions: - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 12 (permalink) Old 11-24-2012, 09:24 AM Thread Starter
Smile Stage 1 suggestions:
Hi everyone, I have a 2008 Road Glide and I am going to do a stage one upgrade, I would like your suggestions on slip on pipes, air cleaner set up, and which fuel module to use.
thanks for your help.
landyacht1967 is offline
post #2 of 12 (permalink) Old 11-24-2012, 10:30 AM
Fire-Medic's Avatar
Ok so my novice 2 cents. First, are you going to have the bike professionally tuned or not? If so then use whatever fuel module (tuner) your guy works best with. If not then you have a few options, but I had great results with a Thunder Max with auto tune on my last bike, tunes while you ride. There's also the Dynojet Powervision with the auto tune basic software on the unit itself, so you can see what's going on while you ride, you can also add the wide and sensors to this like the Thundermax.
As for pipes, this is as personal as what type of women do you like. Go out and listen to as many pipes as you can and pick what sound best to you. You can go with duals, or a 2-1 setup, for a stage one setup with no other work, it's a crap shoot go with what you like best as far as sounds and looks.
Good luck.
Fire-Medic is offline
post #3 of 12 (permalink) Old 11-24-2012, 11:11 AM Thread Starter
Stage one suggestions:
I was thinking of vance and Hines Monster round slip ons, big sucker or similar air cleaner assembly and there is a new module that is plug and play, sorry can't remember the name off hand; that is the direction I am headed.
post #4 of 12 (permalink) Old 11-24-2012, 07:04 PM
joke's Avatar
You got it right...good winter project.
2009 Mirage Orange
joke is offline
post #5 of 12 (permalink) Old 11-29-2012, 08:30 PM
I say skip all that and go str8 to the SE 120R.....Guess who!? Lol, I've now joined seeing as you've sent me the link.....BTW - your parts have been ordered. Let the work begin early next month.....
tubbyone73 is offline
post #6 of 12 (permalink) Old 12-11-2012, 02:53 PM
I'd look at Fuel Moto and their combo's. If not, The MC has all the parts to do the STAGE1. I did a mix of both. I have the PCV, Head pipe and stage1 air cleaner from FuelMoto and the Performance Touring 4" slip-ons from the MC. If I had to do it again...I'd probably get some different slip-ons but I bought them as part of the deal when I bought the bike new.I like this set-up pretty good. FWIW...I'd spring for the Ceramic coated head pipe. I paid $140.00 to get mine coated AFTER I bought it.
Clipper is offline
post #7 of 12 (permalink) Old 12-11-2012, 08:02 PM
rageglide's Avatar
That's some funny shit right there Eh. I second the recommendation. :-)
rageglide is offline
post #8 of 12 (permalink) Old 12-12-2012, 07:56 AM
Engine Expert
DragoBikeWorks's Avatar
Where do I start.
1st. question Do you have a good tuner in your area that can? And what is he or she like to use for an EFI system.
There are many to chose from.
PCV
Power V.
TTS
SEPRO
Thundermax.
2nd There are many Air cleaner to chose from which almost 99% are using a K&N filter. Some are larger than others for bigger applacations.
Zippers makes a great one.
Arlen Ness.
SE.
etc.,
3rd, Exhaust
There are many to chose from. Just make sure you pick one that can grow with your engine needs in the future just in case you want to do more work...power
2:1
2:1:2
Slip ons
True duals
You need to find one you like the looks style and performance and sound.
If you want to talk with someone just give me a call or Im sure there are other Vendors here that can help you also.
Thanks FD.
When Others Promise Power We make it Happen. Quality-Performance-Respect-Drago's Bike Works 815-765-1790
DragoBikeWorks is offline
post #9 of 12 (permalink) Old 12-12-2012, 08:10 PM
If you buy a decent 2 into 1 it will work well now and better when and if the build grows later. The Dragula is what I recommend to customers lately and they always have delivered good torque and horsepower.
Deweys is offline
post #10 of 12 (permalink) Old 12-15-2012, 12:23 PM
I'm going to try this set up.
Fuel Moto all the way
1. FM/Jackpot Header-ceramic
Will use stock mufflers, time will tell if i get their mufflers.. save 400.00
2. FM ac that retains stock cover
3. Their PCv or the mini tuner????
Thats All Folks!!;-)
2013 Road King Classic.. Big Blue Pearl.. With Hard Bags Damn this switch makes me mad!! should be able to order it that way!!!!
Was going to order it from factory but found a BIG BLUE in Nashville , so i said YES .my
salesman {good Man} is going over their Tuesday to pick it up.
I will get it on Thursday. ;-)))
OOps sorry babble on about my bike!
Good luck with your set up!!! ;-))))
netnut is offline
