Should I get a Throttle Body and Injectors?? - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 7 (permalink) Old 11-24-2012, 11:01 AM Thread Starter
I am having CNC heads put on my 103" that are ported and polished and they have bigger valves, I am keeping the compression ratio at 10:1 to 1 so I am wondering if the 58MM throttle body with upgraded injectors would be beneficial or will the stock 50MM TB and injectors work well with this upgrade? I do a lot of touring and I don't hot rod to much (I get on it now and then) but I like the power to pull on long grades and to pass without downshifting.
post #2 of 7 (permalink) Old 11-24-2012, 12:28 PM
Depends on a lot of factors . First call an engine builder. Second more than likely you can port your current tb and use the current injectors. My brothers 124 has the 5.3g injectors and works really well. He also has the 58mm th and works well. Try porting the Tb first and run look at injectors later.
spokanebagfan is offline
post #3 of 7 (permalink) Old 11-24-2012, 08:43 PM
rageglide's Avatar
You looking for max horsepower and high rpm? 50mm is sufficient if you're not looking to break into the 120+ range MY opinion... My 95" build with stock 50mm made plenty of power.
rageglide is offline
post #4 of 7 (permalink) Old 11-24-2012, 08:52 PM
Yeah my buddies 95 was nice with the 50 mm tb and now rips with his 54 mm tb. Call a builder.
post #5 of 7 (permalink) Old 11-25-2012, 10:02 AM Thread Starter
From what info I am looking up the stock will be fine for the build that I will have so I am going to stick with the 50 mm for now.
post #6 of 7 (permalink) Old 11-26-2012, 05:44 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
Your 50 will work fine in your application.
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
post #7 of 7 (permalink) Old 11-26-2012, 06:51 AM
prodrag1320
Guest
Posts: n/a
when thinking of a larger TB,give thought to where you want the power,if its down low,stick with the stocker.if your looking for high RPM power,a bigger TB is the ticket,but one thing alot of riders/builder overlook is runner size,bigger runners on a smaller TB will make more of a CFM increase than a bigger TB with stock sized runners
