Pushrods - Page 2 - Road Glide Forums
post #11 of 16 (permalink) Old 11-28-2012, 08:35 PM
For mild bolt ins the convenient affordable solution are the SE part 18404-08. From there I move to Smiths and those are custom for the application, wall thickness varies as does the lengths I use according to whether or not the stack height is very far from stock. I use the evo lower tubes 17938-83 and the SE spring clips 17634-99 with all of the Smiths pushrods and do not order their "fast install" kit under any circumstances.
Deweys is offline
post #12 of 16 (permalink) Old 11-28-2012, 09:28 PM Thread Starter
How are these two different and which ones are recommend?
18404-08
17997-99A <link>
I don't see the earlier ones listed on HD's site.
2011 RGU Vivid Black | Madstad 16" | T-Man 555c | T-Max | HD Heavy Breather | Dragos S/C/S True Duals | Rinehart 3.5" w/Turndowns | Harley Goodies
ksarauer is offline
post #13 of 16 (permalink) Old 11-29-2012, 05:28 PM
The early pushrods (-99) are not tapered.
No issue with bolt in and lower lift cams and stock or near stock stack height assuming the rocker stands are centered during reassembly. The place where they can rub is at the crimp in the top inner tube.
Deweys is offline
post #14 of 16 (permalink) Old 11-30-2012, 05:35 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
WE do not need to go any farther, than calling the trusted source that we have relyed on now for years.....................S&S.
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
post #15 of 16 (permalink) Old 12-03-2012, 11:48 PM
Like was stated here the SE are the way to go, the last set I bought was $165.00 at Harley Dealer.
chuck the wrench is offline
post #16 of 16 (permalink) Old 12-04-2012, 12:25 PM
rageglide's Avatar
I've used the -99 pushrods (SE kit) with Woods TW-6H without any interference issues.
I always thought the rubbing location was at the bottom of the upper tube, not at the top.
rageglide is offline
