SE 103 HO KIT Throttle Body Noise - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 15 (permalink) Old 11-29-2012, 05:53 PM Thread Starter
RCKYMTNRDR's Avatar
So here is my issue: Brand Spanking new 2013 RGC. Before I took from the dealer I had them instal:
SE Stage IV 103 HO KIT
SE heavy breather
V&H 2 into 1 PRO PIPE Stainless
Ive put 1,000 mile on and it pulls HARD!
However when I have it at idle it makes a slapping sound that I have never heard on any of my other Harley's . Took it back to the Dealer so they could troubleshoot the problem. They came to the conclusion that it was the 58mm throttle bodies butterfly valve banging against the throttle body casing. They ordered a new throttle body and replaced it. Picked up yesterday and it is still making the noise!
Has anyone experienced this issue before?
Sent from my iPad using MO Free
RCKYMTNRDR is offline
post #2 of 15 (permalink) Old 11-29-2012, 06:32 PM
Common
It is reversion in the manifold and the manifold, that combination.
Similar sound to a mikuni slide rattle but less.
Deweys is offline
post #3 of 15 (permalink) Old 11-29-2012, 08:04 PM Thread Starter
RCKYMTNRDR's Avatar
Deweys thanks ..... but still not quite clear on what you mean by manifold and manifold combination?
post #4 of 15 (permalink) Old 11-29-2012, 08:11 PM Thread Starter
RCKYMTNRDR's Avatar
Oh sorry man I think I got what your saying, OK if I understand correctly it is the reversion of air? Is that just the way it is.. Or do you recommend a solution?
post #5 of 15 (permalink) Old 11-29-2012, 11:13 PM
All of them pulse in the manifold, with more overlap it gets worse. The TBW throttle body is servo motor controlled and I have heard them do this even on stockers after the Air Cleaner is substituted for an open element type (so this type of thing can be heard unmuffled). I think the Cable TB has more pressure to hold the blade shut so it does not flutter like that, at least that is what I suspect may be the issue, I honestly don't know this 100% for sure.
Deweys is offline
post #6 of 15 (permalink) Old 11-30-2012, 03:42 AM
It's the FBW stepper motor.
They all do that.
My HPI TB is real noisy, you just get used to it.
2010 Vivid Black Road Glide Custom
Mike Jesse is offline
post #7 of 15 (permalink) Old 11-30-2012, 04:27 AM
FrankieB's Avatar
If it sounds like two pieces of wood knocking together then more then likely it is reversion.
06 RK
11 RGU
FrankieB is offline
post #8 of 15 (permalink) Old 11-30-2012, 06:43 AM
Engine Expert
DragoBikeWorks's Avatar
Not trying to scare you I hope that's what your noise is. ( Not piston slap.)
A simple way to tell is to cover up intake /air cleaner sound should almost go away.
Does it get worse when you are riding?
When Others Promise Power We make it Happen. Quality-Performance-Respect-Drago's Bike Works 815-765-1790
DragoBikeWorks is offline
post #9 of 15 (permalink) Old 12-01-2012, 07:47 PM Thread Starter
RCKYMTNRDR's Avatar
No it goes away once I slightly crack the throttle.
post #10 of 15 (permalink) Old 12-01-2012, 08:03 PM
tdkkart's Avatar
As the others said it's most likely reversion, caused by camshafts that actually have overlap(intake and exhaust open at the same time). Scares the crap out alot of folks when they hear it after having an open air filter the first time.
Put the stock air cleaner on it long enough to check, I'll bet the noise goes away.
tdkkart is offline
