SE110 heads - Road Glide Forums
post #1 of 9 (permalink) Old 11-30-2012, 11:31 AM Thread Starter
SE110 heads
I have a 2011 RGUCVO with a stock SE 110 w/Rinehart classics true dual , Thundermax auto tune. My question is... what can I do with the stock SE heads to get a little more hp and torque. Is it worth spending money on these or should I look to upgrade other components as well?
brfs4 is offline
post #2 of 9 (permalink) Old 11-30-2012, 11:38 AM
Fire-Medic's Avatar
If you are bored with where you are at, I would say dump the 255 cams that are in their first and go from there. Just a cam swap would really wake that motor up, but a cam swap with heads to compliment the cams would be sweet.
FM
Fire-Medic is offline
post #3 of 9 (permalink) Old 11-30-2012, 12:11 PM
CNMTurner's Avatar
Following on to Fire-Medic.. the 255 cam is a stump puller down low in the rpm range... but runs out fairly quickly. Longer pulls can be achieved by different cams. .. I've read where Fueling 574, andrews 54 work well in a 110. But.. I'm no performance expert.. but the first thing they will ask, is what you are unhappy with and what do you want to achieve..
I'd love to hear from the sponsoring experts.. Drogos, Hillside and Fuel Moto? Any suggestions?
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #4 of 9 (permalink) Old 11-30-2012, 04:21 PM
Afraid you may be looking at the wrong part to mess with. The heads can perform well with added compression (milling) and a cam change.
Power into the teens and 125 torque is possible. Want more? Then don't dabble, headwork with bigger valves, larger TB, and pistons.
The HD stage 3 kit piston and 259 cams plus head work has yielded 126/124 in my experience. More yet with a little more cam.
Deweys is offline
post #5 of 9 (permalink) Old 01-14-2013, 11:51 AM Thread Starter
No head work
Talked to tech at dealership Saturday. heres what they recommend.
New 58mm TB
259E Cams
running SE110, thundermax auto tune with Rhinheart classic true duals
I still want ridablitiy with good tourque @ 3-6 rpm
Thoughts , comments ,or suggestions?
brfs4 is offline
post #6 of 9 (permalink) Old 01-14-2013, 05:57 PM
prodrag1320
Guest
Posts: n/a
headwork,S&S .570`s set @ 9.8-1 makes a very nice mild 110 build,we get 116/123,
post #7 of 9 (permalink) Old 01-14-2013, 08:24 PM
faceracer's Avatar
Send a message via Yahoo to faceracer
Depends how radical you want to go
I lost 15 ft-lbs of touque at takeoff due to changing from a 255 to a andrews 54. I am very happy with what I have now but according to doc It would have had better numbers with some headwork and stock cams and a good dyno tune. Just my two cents. Here is my dyno thread:
Angry Bird gets a Dyno by Doc's
I also believe the heads are too big for the 110 and the intake could be made smaller and gain some torque. My opinion after talking extensively with my local wrench who is doing allot of different setups for people. He is getting more torque out of 103's with cam and headwork. They also posted a dyno chart with 114 ft-lb of torque with a 2013 103 with hd's stage 3 kit. They had the bike on display with ask to ride sign!
Face
2009 CVO road glide Electric orange & Vivid black, Andrews 54 cams, Cometic .030 Head Gaskets, Dragoís Dragula 2-1 Black header with left ghost pipe, TTS Master with Dyno tune by Docís Performance,
faceracer is offline
post #8 of 9 (permalink) Old 01-14-2013, 09:48 PM
Similar deal to the old HTCC on a 95". If a guy chose the right cam they made decent torque and were very rideable plus made power. They are not too big but get that way real fast with what seems like a standard issue cam for a 96 or 103 motor with stock or mildly ported heads. Try a cam with about 235 duration 103LSA 30 overlap or thereabouts and change the head gasket to a 30
Deweys is offline
post #9 of 9 (permalink) Old 01-15-2013, 06:01 AM
Engine Expert
Send a message via AIM to Hillsidecycle.com
Yes, the headwork can/will bring more, and the correct cam swap will spread the power over a larger rpm band, and help tame some heat, vs that 255 cam.
Depending on your riding wants and needs, there are several options.
Happy to help..........
Scott
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST.
MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
Complete HD machine shop
Complete HD cylinder head shop
High Performance Engine Kits
Goodson HD Tooling Manufacturer
Direct Link Dyno Tuning
HD Extended Warranty Center
MMI Certified Mechanics
S&S Cycle Warranty Center
Walk-in Retail Store
Maxton Mile Land Speed Class Record
30 years of Harley-Davidson engine building.
Hillsidecycle.com is offline
