Just finished my first Harley engine rebuild and these are my thoughts on the whole thing, forgive me if my writing aint the best but i never cared for English class very much (bad teachers? :grin
Build run-down: 2006 FTRI 72,000 miles
-S&S 4" crank+ SE lefty bearings
-SE 95" Std Flat tops (-.001" to -.002" deck height and .040" MLS gaskets)
-Cyl.s and heads machined by Hillside Motorcycle & Machine (Heads: Super Stock valve job and CC'd for 9.5 static comp+ C/R's added)
-Andrews 21N cams + the suggested HD parts to complete conversion
-S&S standard lifters+ SE tapered adjustable push rods
-S&S rocker shafts and barely used stock rocker arms
-SE Stage 1 K&N a/f
-S&S PowerTune Duels (fricken love this header) + now discontinued? Bassanni Super Saver mufflers think the baffles are 2"x18" louvered
-POWERVISION + AUTOTUNE 110 module (love this too)
-SE Clutch spring
Kind of a joe minton build i guess
First i would have to say that this has to be the easiest engine to work on, without timkens on the crank i literally bought a press from harbor freaight + the special tool for the bearings and i rebuilt this engine in my bedroom (i dont have a garage or shed but the bike fits in the bedroom lol).
I know im sure to hear that i could have had more power for the same money (more stroke,bore,cams...) but i dont want it and my budget was tight as hell and i blew it anyway (i stopped counting at $4k but i dont think it went over $5k, i did already have pipes, a/f, and powervision but not a/t) If i had more power than this im sure the trans and primary would be coming out very shortly and i dont have money for that and i wanna ride the thing not wrench forever more. Plus, with the S&S flywheels they truly are infinitely rebuild-able and when this motor gets tired i think ill have replaced/upgraded the driveline and i think i like the idea of an all-bore 107 and gear the bike lower.
Im loving this thing so far and havent revved it over 3500 rpm yet, i dont think you would ever have too really but i can tell it definitely wants to keep goin, i pretty much shift at 4500-5000 if im gettin after it so if peak hp is like 5200 im good with that. Typically cruise around between 2500-3500. This thing really is like a pack mule or billy goat when you reach a steep hill, barley roll the throttle on and it climbs without hesitation, only detonation i experienced was @ ten miles on the first ride and i was like take it easy Willbo its like a newborn right now haha. i have run 3 good a/t sessions and have since just been trying to put miles on it so i can stretch the rpms and see how she feels.
Idle sounds prominent (just thumps harder with added CCP) and you can tell the cam has a bit of overlap. I've always felt like 9.5 comp with a "small" cam was the way to go for any daily driven engine, its safe and reliable if you happen to get shit gas one day. built a chevy 350 like that a few years ago for my pickup and i supprised a lot of folks because the idle was mellow and the gearing was right. That said @ about 170 miles i checked CCP on this 95" and was @ 182psi and 185psi.
Big thanks to Scott at Hillside for the great machine work and answering my questions, i had pretty much figured out what i was gonna do and had started buying parts when i called Scott about machine work and just double check the path i was on. They even threw in a free small pocket knife with my heads so extra thanks for that as well. I will probably dyno this thing once its broken in cause id be curious to see the TQ numbers and to see how good the auto tune is. I'll make that a seperate post of that.
Thanks for reading, i always like reading about other's builds so i thought i post mine + i wanted to Thank Scott again without bugging him on the phone lol seriously tho he was great to speak with. Take care all and keep the shiny side up!!
-SE Stage 1 K&N a/f
-SE Clutch spring
