255 SE Cams And V&H FP3 Being Installed - Road Glide Forums
 67Likes
post #1 of 64 (permalink) Old 03-28-2017, 08:34 AM Thread Starter
Swomack's Avatar
Well I have ordered the parts.
Harley Davidson 255 SE Cams And Vance & Hines / FP3 Fuel Management System.
Should have everything in my hands by the end of the week, then it goes into my dealership to have them do the install.
I will also have a the full maintenance done on my bike along with have having a new rear tire put on.
Should be a nice little upgrade.
There are many aftermarket cams out there but I have read the reviews on the 255 SE Cams, and have heard great things.
My buddy put them in on his SGS and I have to say wow, nice difference from stock.
If your not familiar with the Vance & Hines / FP3 Fuel Management System, you might want to check it out on you tube.
A great little system that allows you to AutoTune your own bike with great results.
I'll post up the results once the installation is complete and I have put on some miles.
http://fuelpak.vanceandhines.com/
https://www.youtube.com/watch?v=pQkbnUyPIYY
Swomack
2015 Roadglide Special / 49,400+ Miles
It's All About The Ride & Brotherhood
Swomack is offline
post #2 of 64 (permalink) Old 03-28-2017, 09:09 AM
Dragon Dude's Avatar
You will enjoy the added HP and torque the cams give you. Looking forward to hearing how you like it over stock.
Swomack likes this.
2013 Road Glide vivid black
Dragon Dude is offline
post #3 of 64 (permalink) Old 03-28-2017, 09:24 AM
RFG7680's Avatar
Are they going to put the bike on a dyno and use the FP3 to tune? Or are you loading the V&H map and running auto tune?
RFG7680 is offline
post #4 of 64 (permalink) Old 03-28-2017, 09:31 AM
BlazingSaddle's Avatar
Swo, I don't doubt you've done extensive research on cam choice, and that the difference in performance of your buddy's SGS helped seal the deal for you. So it begs the question, if the Rushmore 103 HO's cam is professed to be the 255 with very slight difference, why such a difference in performance? Does your buddy's bike have some parts on it that might be improving his performance that much over yours? Maybe someone else can chime in as well.
mastergunnera8 and NorCal like this.
BlazingSaddle is online now
post #5 of 64 (permalink) Old 03-28-2017, 12:04 PM
I found this:
[IMG]2013 cams Lift int/exh .484/484 dur @.053 int/exh 198/220 2014 cams Lift int/exh .484/484 dur @.053 int/exh 213/233 SE-255 cams Lift int/exh .556/556 dur @.053 int/exh 211/235[/IMG]. I don't know if it helps, but all i could find on some differences between them.
post #6 of 64 (permalink) Old 03-28-2017, 01:17 PM
08Zinc's Avatar
I hope that you're as happy as I am with my recent mods. I had a .255 on a 103 in a pre-Rushmore bike and loved it. Almost went with the .255 again. Enjoy, Swo.
Swomack likes this.
Regards, Zinc -
BATTLEFIELD HARLEY IN GETTYSBURG, PA IS A DISHONEST DEALER. USE THEM AT YOUR OWN RISK.
555 cams, Jackpot exhaust, Ness Inverted AC, 21/17" Xtreme Machine Fierce wheels, Progressive Monotubes, Super Shox, True-Track stabilizer, etc.
08Zinc is offline
post #7 of 64 (permalink) Old 03-28-2017, 01:22 PM Thread Starter
Swomack's Avatar
I'm going to do the normal maps then auto tune it.
Should be better over then my current setup.
If and when I have extra cash floating around I might put it on a dyno but for now I'm going to use the FP-3 Auto tune software. On my buddies bike I noticed better throttle response and the bike was quicker between the 3,200 rpm and 4,200 rpm. The bike will not run as hot and the deceleration popping will disappear.
Swomack
Swomack is offline
post #8 of 64 (permalink) Old 03-28-2017, 03:26 PM
FLTREX's Avatar
This link lists the cam specs of the different Screaming Eagle cams as well as the 103 HO.http://www.harley-davidson.com/app-c...ison_Chart.pdf
FLTREX is offline
post #9 of 64 (permalink) Old 03-28-2017, 03:57 PM
Originally Posted by Dragon Dude View Post
I found this:
To be clear, the 103 HO cam is no SE255, just that I had read (on the internet..lol) it was similar in specs. In another forum, there's a pretty cool detailed graphic which reflects intake and exhaust timing and duration of the 2013 cam vs 2014. It's in that graphic they're saying the timing specs of the HO cam are closer to the SE 255. Me, I dunno, which is why I thought I'd ask. I like the longer duration of the SE255 vs the stock. Should be fun!
post #10 of 64 (permalink) Old 03-28-2017, 04:13 PM
SE255 cams in a 2013 RGU
Hey good luck with your bike, the SE255's are great, don't believe the "school bus" analogies etc. You've got a bike that weighs in at 875ish pounds.... it's not a rocket.... Who runs a bike at 5000 plus rpm's all the time anyway? But it will get up and go. You will be happy!! CSM-H
Swomack and E56789 like this.
CSM-H is offline
