Looking for 100 hp and 115 torque for under 1500.00 - Road Glide Forums
 10Likes
post #1 of 14 (permalink) Old 04-19-2017, 05:53 PM Thread Starter
sfcusaret2004's Avatar
Stock '13 Roade glide ultra with factory everything except 4" rush big Louie slipons. And..... GO!
G5Driver likes this.
sfcusaret2004 is offline
post #2 of 14 (permalink) Old 04-19-2017, 11:35 PM
And hopefully reliable as well. Should be doable with a solid cam, the right map, and full exhaust system. I had a 103 at 108hp and 118tq, but did have some headwork done.
bikepsych, 2017 RoadGlide Ultra
Bone Stock
bikepsych is offline
post #3 of 14 (permalink) Old 04-20-2017, 12:03 AM
calgaryglide's Avatar
Is that 1500.00 all in, parts, labor and tax?
We have some great engine builder sponsors of this site, give them a shout or reach out to them by email for the best advice, after all they do it all day long.
Calgaryglide
calgaryglide is offline
post #4 of 14 (permalink) Old 04-20-2017, 12:14 AM
Taccone's Avatar
Intake, Good 2 in 1 exhaust (D&D Fat Cat or Dragos Dragula), Cam and tune should put you right about there! You can prob pick up the intake or exhaust slightly used online in some sort of forum.....
ironmark likes this.
Taccone is offline
post #5 of 14 (permalink) Old 04-20-2017, 08:59 AM Thread Starter
Just to clarify, I'm looking for specific parts. Labor is no factor. Which cam, intake, exhaust, tuner combo did you use to achieve this goal? How close did you come? I realize there are builders that are great sponsors of this site, but I'd like to hear form the actual riders themselves, to see how satisfied they are with their builds and again which specific components they used to achieve their numbers. Thanks for participating.
post #6 of 14 (permalink) Old 04-20-2017, 03:19 PM
HarleyJack's Avatar
Me thinks it would be difficult for $1500 , spend that on exhaust and a cam ..
2011 Ultra
HarleyJack is offline
post #7 of 14 (permalink) Old 04-20-2017, 03:30 PM
SteadyEddie's Avatar
I say do a Solid Stage 1 (Intake, 2:1 and ECU) and use the money on a Dyno - $1500 will be tough IMHO as I know it:
Good 2:1 = $850 at least (used)
Intake = $200
ECU = $150-$300
Cams = $250'ish
This is your $1500 if you score eBay and piece it together with the best of luck - Now, proper install and tuning is a whole other beast
Might I ask why 100/115 is the Goal? - Do you just want red light to red light power or hwy passing power?
I think a Good Stage 1 (properly dyno tuned) and some good rear shocks would out perform a missing 15 hp or so of that 100 mark.........but that is just me
SteadyEddie is offline
post #8 of 14 (permalink) Old 04-20-2017, 04:36 PM Thread Starter
Intake = $200
ECU = $150-$300
Cams = $250'ish
the numbers are kinda arbitrary but around what I want in terms of power and speed. I'm tired of getting smoked by bros with stage 2's and way more cash than I have access to. I'm no hot rod but do a lot of highway riding back and forth to work, (in Michigan that equates to 75-80 MPH) and don't like being in proximity to idiots on the road, so having the power to pull away at speed is important as well. Dragos "diablos 1.5" looks promising for the coin, but we'll see...
post #9 of 14 (permalink) Old 04-20-2017, 06:46 PM
turbochrisb's Avatar
Dragos has some really decent deals......ESPECIALLY if you can take it to him for the labor.
2006 RoadGlide Dragos 98" Stage 2.5, TTS, Dragula 2, 16" Malos, 970s & Monotubes, lots of black stuff. 110 hp / 106 tq
turbochrisb is offline
post #10 of 14 (permalink) Old 04-20-2017, 08:39 PM
I helped a buddy with the same thing as cheap as possible but it was more than your budget but got those numbers. I found him a barely used set of fullsac DX pipes on Ebay, 4" rineharts, HD heavy breather, S&S cam installed and dyno tuned by Chris Rivas (Fresno, Ca). Runs and sounds awesome
bluecollar84 is offline
