Andrews 48 or 54 cam - Road Glide Forums
Sponsored by Drago's Bike Works
post #1 of 11 (permalink) Old 02-09-2011, 07:32 PM Thread Starter
2010fltrx's Avatar
Im going to install cams in the next few weeks and was looking for feedback with the andrews 48 and 54 cams. also looking at the wood tw555 but they are way more money. Dynos anyone?
2010 Road Glide, Bub 7 true duals, Power Commander V with Autotune, Screamin Eagle Heavy Breather, Paul Yaffe 14" monkey bars, Andrews 48H cams
2010fltrx is offline
post #2 of 11 (permalink) Old 02-09-2011, 08:40 PM
I read for two months and decided to go with the Andrews 54H. I don't have the bike running yet so I can't say much else. The 48H is pretty new and there isn't much information on it.
robertg is offline
post #3 of 11 (permalink) Old 02-09-2011, 08:57 PM
A big factor is going to be is your engine a 96" or a 103"? I've researched this as well, and there's also a good thread on hear from FLTRI, and his 48 install. You should be able to find it with a search.
The 48 was designed as a bolt in cam for a 96" motor. You can put one in a 103, but you'll need to keep the CR down in the low-mid 9's. Whereas the 54 is for 96"-103" with a CR around 10:1. So it all depends. If you already have a 103, then the 54 is probably more practical, as a 48 would likely require pulling off the top end to correct the CR with new pistons, head work etc.......$$$$$
I'm going with a 48H in my 96" bike, but won't have any idea how it runs until Apr-May. Good luck...you could drive yourself batty deciding on a cam!
Jeff
akjeff is offline
post #4 of 11 (permalink) Old 02-09-2011, 08:58 PM
Wooden Nickel
Guest
Posts: n/a
I have the 54H's in my 2011 FLTRU but unfortunately I haven't rode it because of the snow and otherwise terrible winter weather. I can say that my dealer has done a lot of bikes with the 54's in them with very good results. They haven't done any 48H's because I asked. The Master Tech that does the Performance Mod's said my bike ran real well with them. I don't have Dyno numbers because of the Pro Tuner with Smart Tune and I don't feel like beating the bike up on a dyno. I also believe the Tech has them in his bike. I have two other HD's with Andrews and have been very happy.
Fullsac.com has dyno results on their site with the 96's and a 103 Ultra Limited.
post #5 of 11 (permalink) Old 02-10-2011, 07:15 AM
Bluzmn59's Avatar
Doc is putting TW-555's in my FLTRU (103) later this month. I am also going with the Jackpot 2-1-2 exhaust with Rush slipons. I will be posing dyno numbers in a couple of weeks.
Life is hard. It's really hard if you're stupid.
1959 FLHF
2007 FLSTSC
2011 FLTRU
Bluzmn59 is offline
post #6 of 11 (permalink) Old 02-27-2011, 08:24 AM Thread Starter
2010fltrx's Avatar
Talking 48h
Well after hours and hours of searching and looking through tons of peoples dyno numbers, i made an adult decision and went with the 48h cam. I am a horsepower nut with my car and truck. My duramax is all tuned and a rocket and my chevelle is twin supercharged. However i do most of my bike riding on back roads and with my very understanding wife. The 48h should be an awesome torque cam for the low rpms i ride. I am hoping for 85hp and 95ftlbs which is a tad better than most se255 numbers. I however wont find out what it feels like until the GD snow goes away. Just woke up to another 6 inches of snow. The cam installer said she pulls pretty good on his very cold test drive though I am dying to ride!!!!!!!! Should get it to the dyno soon and will post the sheet and some numbers for everyone.
post #7 of 11 (permalink) Old 02-27-2011, 10:48 AM
Just to show you, this what I got out of my $50 SE 255 cams in my stock 07 96 in
carguy is offline
post #8 of 11 (permalink) Old 02-27-2011, 11:41 AM Thread Starter
2010fltrx's Avatar
That is exactly what i am looking for in numbers! here's hoping i get similar results! how do you like it? does it feel like a new bike? you should post that in the dyno section we need some more posts!
post #9 of 11 (permalink) Old 02-27-2011, 02:14 PM
I think this is how the bike should come from the factory. Even two up on the freeway I can pass using 6th gear and not have to downshift.
carguy is offline
post #10 of 11 (permalink) Old 03-14-2011, 05:10 PM Thread Starter
2010fltrx's Avatar
Talking
Took the bike for a ride Saturday. MAN what a difference. so much low end power. Best bang for the buck so far. I have a baseline map in right now so will be even better once dyno tuned. Exhaust sounds way more bad ass then before too. My buddy knew I had done something before I got a chance to tell him.
