As said, I'm running an 09-13 pak on my 2015, using the 09-13 detachable mount. It works just fine, but some have had to shim the pak up a bit to clear the bag lids. I didn't have to, mine clear by about 3/16"-1/4".
Lil Chief
Well now the wiring is a different story. You will have to change the plugs on the TP to match up to the rushmore plugs. The rushmore bikes have a canbus electrical system and the connectors are different.
Hmm the old bracket is narrower. The holes would have to be along the edge where it dips
Did you mean to drill the tourpack to run new bolts?
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
