Bike wont start - Road Glide Forums
post #1 of 51 (permalink) Old 12-26-2013, 07:56 PM Thread Starter
Bluchevypick's Avatar
Bike wont start
Well i need help. lol I went out to start my bike after it was under the cover for a few days on the tender and it wouldnt start. It was kicking back and spitting out the breather so i kept trying to start it with no luck. Then i came back later the day and got nothing. The bike has a Stage 4 HD kit with Woods 777 cams and a Thundermax tuner on it.
Fast forward to today. I went out there to try to start it with no luck. So, i hooked up my computer to it and pulled the codes for it. These are the codes im getting:
641 5v Vref1 out of range
2138 TGS Correlation Error
122 TPS1 Lo
2135 TPS Correlation Error
2101 TAC Actuation Error
2176 TAC Closed pos
2105 EFI Forced Engine shutdown
1511 EFI power management
1512 EFI forced idle mode
I di however plug my stock throttle body in and try to start it while twisting the throttle and the blade wont move so im thinking its not my throttle body but i may be wrong. The twist grip sensor got replaced by my stealer about a month ago. Do you think its the sensor or the Thundermax?
Bluchevypick is offline
post #2 of 51 (permalink) Old 12-26-2013, 08:41 PM
Did you try disconnecting the TMAX, putting some dielectric grease in the contacts, then resetting it and starting over again?
Sent from my SPH-L710
dbell66253 is online now
post #3 of 51 (permalink) Old 12-26-2013, 08:42 PM Thread Starter
No i havent but i will try that first thing in the morning along with dielectric grease on the throttle body plug.
post #4 of 51 (permalink) Old 12-26-2013, 08:45 PM
Do both...... I've been there before. If that doesn't work Zippers support should be able to help. Do you by any chance still have your original ECM?
post #5 of 51 (permalink) Old 12-26-2013, 08:47 PM Thread Starter
I do have my stock one but its not setup for the stage 4. I also dont know if i still have my stock o2 sensors
post #6 of 51 (permalink) Old 12-26-2013, 08:54 PM
Its not set for your bike, but in worse case scenario you can see if your bike will start with it to help you determine if the TB or TMAX is your problem.
post #7 of 51 (permalink) Old 12-26-2013, 08:55 PM Thread Starter
Im guessing it will still start without oxygen sensors plugged up? Ill try the dielectric grease first
post #8 of 51 (permalink) Old 12-26-2013, 08:57 PM
If the bike will start with the original ECM then look to the TMAX for the problem, if not look at the TB. You don't have to hook up the O2 sensor, you'll just be testing, not going anywhere.
post #9 of 51 (permalink) Old 12-26-2013, 09:00 PM Thread Starter
Alright. Ill do all this in the morning and let ya know what happens. Thanks
post #10 of 51 (permalink) Old 12-27-2013, 08:50 AM
Hopefully it's something simple.
