Front brakes "squealing"? - Road Glide Forums
post #1 of 9 (permalink) Old 05-15-2012, 01:34 PM Thread Starter
Hey all, just wrapped up my build last Thursday and I've noticed over the weekend that almost everytime I come to a stop I get a weird squeal the last second or so before I stop. Imagine a horror movie where someone opens a rusty door slowly. It's a sound similar to that. I know it didn't make that sound before. It's been nearly a year since the bike was rode, closer to 19 months since being used regularly. Anyways almost everytime I come to a stop I get this noise. There is no wobble and no noise at speed when braking. I have a 21" wheel from SMT machining and spacers from wily shiny. I was thinking maybe beatings aren't fully seated? They brakes and rotors touch very very slightly when on a jackstand. Any ideas?
2010 road glide custom dual rotor, non abs.
Factory brake pads with 3400 miles on them
SGT_Rob
The very essence of leadership is its purpose. And the purpose of leadership is to accomplish a task. That is what leadership does–and what it does is more important than what it is or how it works.
~Colonel Dandridge M. Malone
SGT_Rob is offline
post #2 of 9 (permalink) Old 05-15-2012, 01:53 PM
Take the pads off and use a very fine grit sandpaper to LIGHTLY scuff the pad and make sure the pad to caliper contact points are lightly lubricated. Make sure the rotor is aslo clean.
post #3 of 9 (permalink) Old 05-15-2012, 09:14 PM Thread Starter
you know I didn't even think of lubricating the pad to caliper contacts. The bike has been sitting for quite awhile. It definitely might need a bit of lubricant. What would you suggest using.
SGT_Rob
SGT_Rob is offline
post #4 of 9 (permalink) Old 05-15-2012, 09:47 PM
At work i use a silicone brake lube from ACdelco. A small can of that is about $10 but works great. I would suggest going to your local autoparts store and see what they recommend for a brake lubricant. You will not need to apply much at all and keep it off the pad surface and rotors. That will only amplify the problem
post #5 of 9 (permalink) Old 05-16-2012, 09:41 AM Thread Starter
I thought if I lubricated the pads and rotors it would double their life and be super quiet when I stop!!
SGT_Rob
SGT_Rob is offline
post #6 of 9 (permalink) Old 05-16-2012, 11:56 AM
HD_Shock's Avatar
You mean IF you stop! lol
-phil
2011 FLTRX 103
HD_Shock is offline
post #7 of 9 (permalink) Old 05-16-2012, 06:10 PM
why would you want to stop?
post #8 of 9 (permalink) Old 05-16-2012, 06:11 PM
Fat Tom's Avatar
I use a little silver grade never sieze on any contact points between pad and caliper, and never get a squeak.
2006 Road Glide
Fat Tom is offline
post #9 of 9 (permalink) Old 05-16-2012, 11:38 PM
We use a disc brake quiet spray from Napa when we do pads at our shop to help keep things quiet....and it works very well....
Cheers,
Trent
Dfwhockey17 is offline
