I Have Had It - Page 2 - Road Glide Forums
post #11 of 26 (permalink) Old 10-05-2012, 12:45 AM
rageglide's Avatar
Here's what I'm talkin about, granted this is how I have it on my softail.
Notice that I have plugs on the adapter plate lines that S&S provides. Not using them! The line is routed to the ground. On my '05 the line ran up along the frame and down to the ground behind the transmission.
Big motors need to breath inside and out. Evo's and twinkies do not breath worth a shit internally.
rageglide is offline
post #12 of 26 (permalink) Old 10-05-2012, 04:59 AM
Radioactive's Avatar
Mine will puke oil until it's about six dots from low mark on the dip-stick. My engine builder said as long as it's at or above the low mark I would have no problems.
Radioactive is offline
post #13 of 26 (permalink) Old 10-05-2012, 07:28 AM Thread Starter
CR3999's Avatar
Get a breather set up that allows you run the lines away from the intake. The intake routing everyone uses now days is clean *looking.
Where can I get one of these? And who makes the best.
17 Road Glide Special
CR3999 is offline
post #14 of 26 (permalink) Old 10-05-2012, 12:18 PM
rageglide's Avatar
I'm showing a pic of an S&S set up. The key is that you need a set up that has banjo fittings external to the plate. Plug up the fittings/holes that the external lines would pass through of course.
I have seen a few mfgr's use this external method but I have only used S&S and the older Screamin eagle versions.
post #15 of 26 (permalink) Old 10-10-2012, 11:24 PM
Phantom6722's Avatar
RTFM you could be overfilling it. On my CVO there are two oil level marks on the dipstick one for cold and one for hot levels. The cold level is about 1/3 of the up the dip stick from the empty mark. Both levels require the bike to be on the side stand when checking the oil level, which is different to my Heritage.
Cheers Skip
Phantom6722 is offline
post #16 of 26 (permalink) Old 10-25-2012, 10:37 PM
Question for the low oil level folks...since you're running lower oil, do you experience higher oil temps? It would seem to me that less volume of oil to absorb heat would result in higher sump temps of the oil resulting in quicker breakdown of oil especially on our air cooled engines. Add in some higher performance parts resulting in warmer temps and more demand on the oil and now you want all the cooling oil you can get. If your oil is returning to cooling, scavenging, and lubricating duties quicker because there is less of it, you'll need to change it more frequently.
It seems to me that there must be an answer. Other manufacturers do not have a problem with oil filling up the air filter, why do we tolerate it? I had an old boss that told me "You deserve what you tolerate." Do we deserve to have to worry about this? I say no. But what's the answer?
bikepsych, 2017 RoadGlide Ultra
Bone Stock
bikepsych is offline
post #17 of 26 (permalink) Old 10-26-2012, 10:53 AM
skratch's Avatar
i would say in theory you are correct. but the reality is how much cooling does that 6-8 oz of oil actually give you?
and, remember, we aren't running our oil low. we are just running below the full mark, but still in the operating range.
skratch is offline
post #18 of 26 (permalink) Old 10-30-2012, 04:58 PM
rustyj671's Avatar
After I did my last oil change, 3 quarts brought it to halfway between low and full on the dipstick. I haven't experienced any puking. I do however smell oil and trans fluid after running highway speeds, then stop and go traffic. I still haven't seen a leak.
'12 FLTRX ==> PV w/ TT, PM Super Gas A/C, Dragos 580 cams, Fullsac DX pipe and 2" baffles in stock muffs, 18" Badseed bars, Custom Dynamics lighting, Dunlop AE tires w/ Ride On, JL Audio amp, Polk speakers, Pioneer inner fairing speakers, Progressive Monotubes, Bitchin Baggers Rear Shocks, Alloy Art Stabilizer and Cush Drive, GMR Compensaver on SE compensator, Rush Cycle Pedic seat....all thanks to this forum.
rustyj671 is offline
post #19 of 26 (permalink) Old 10-30-2012, 07:10 PM
Ironrider's Avatar
Wow this is interesting makes me wonder if your oil is returning to the reservoir
Sent from my MB860 using Motorcycle.com Free App
Ironrider
Ironrider is offline
post #20 of 26 (permalink) Old 11-11-2012, 03:00 PM
dannyfromoz's Avatar
Blowing oil
Originally Posted by CR3999 View Post
Man, what is up with the oil blowing out the breath every time I get on the road. It is not over filled, my Fatboy would puke oil out if it was a little on the high side. But I don't over fill my bike with oil. If the oil gets about a quart low it pretty much stops puking. It just pisses me off to wash the bike and wax and a hundred miles down the road oil everywhere. What do you folks do to stop this?
Man I feel better now.
When I would change oil AND filter on my bike I would put in one less quart than was specified. Then after I run the bike for at least 5 minutes I would shut it off and check the level again to see if the oil filter drank it' fill. If it was still low I would add some more oil.
DannyFromOz
dannyfromoz is offline
