Electrical Problem Tonight - Road Glide Forums
post #1 of 11 (permalink) Old 11-08-2012, 07:51 PM Thread Starter
while riding to work tonight on my 2012 FLTRX, the check engine and battery light came on and the voltage dropped to just above 10 volts. This lasted for about 3 minutes, then the voltage climbed again back to normal and the trouble lights went out. Any ideas?
Chris
"Those who would give up essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." -Benjamin Franklin, 17 Feb 1775
FLTRX372 is offline
post #2 of 11 (permalink) Old 11-08-2012, 07:58 PM
Redfish-Joe's Avatar
Check all the battery connections. Don't forget the frame ground too.
Redfish-Joe is offline
post #3 of 11 (permalink) Old 11-08-2012, 08:04 PM
I'd say the voltage regulator is letting you know its going to go.
dbell66253 is online now
post #4 of 11 (permalink) Old 11-08-2012, 08:33 PM
Triplej's Avatar
Time to check for any DTC's.
How to Find your Diagnostic Trouble Codes
Give us some more info on your bike (year, mileage, recent mods, etc.) and what, if any, codes are showing. Like already said by Redfish-Joe and Dbell66253, among other things it could be a battery/ground problem or a VR on its way out. When checking the Battery cables be sure to check both ends of both cables and apply some dielectric grease to the connections.
If you had noticed a spike in voltage as well as a drop in voltage it would more than likely point to a bad VR.
Electrical issues can be a real booger to narrow down
Triplej is offline
post #5 of 11 (permalink) Old 11-08-2012, 10:02 PM Thread Starter
Thumbs up My electrical problem tonight
No mods, stock '12 custom shark. Hopefully call volume will slow down to the point that I can check those battery connections. I just happened to have my service manual at work, so I'll look there to see where the frame ground is. She just turned 10k miles a few weeks ago.
Chris
FLTRX372 is offline
post #6 of 11 (permalink) Old 11-08-2012, 10:32 PM
tdkkart's Avatar
'12 models with bad voltage regulators are unfortunately a well know problem.
Talk with your dealer and they'll probably swap it out for you.
tdkkart is offline
post #7 of 11 (permalink) Old 11-08-2012, 10:40 PM Thread Starter
Having trouble finding the frame ground in my service manual, any suggestions?
FLTRX372 is offline
post #8 of 11 (permalink) Old 11-08-2012, 10:53 PM Thread Starter
I checked for codes; for each letter I either got "no rsc" or "none". When I clicked the button again, I was shown a part number for S (68920-07), SP (67261-08), and t (67459-04C).
FLTRX372 is offline
post #9 of 11 (permalink) Old 11-09-2012, 04:13 AM
Triplej's Avatar
Odd that its not throwing any codes. Being a 12 model I would do like td suggests and let the dealer fix it under warranty.
Triplej is offline
post #10 of 11 (permalink) Old 11-09-2012, 05:06 AM
Mischief's Avatar
This is most likely the issue. Many threads on it. Symptoms sound exactly the same. Keep an eye on your voltage and I would go back to the dealer before you get stuck
2012 FLTRU / 2001 Custom Hayabusa
Mischief is offline
