Hidden Fairing Damage - Page 8 - Road Glide Forums
post #71 of 87 (permalink) Old 02-26-2012, 12:45 AM
SharkBite's Avatar
It shouldn't be on yours but it was on my 2010.....just found the damage when I took the fairing off to put in new speakers, antenna and garage door opener......took the vice grips to it and bent both sides in....hopefully it helps
2017 Roadglide Ultra in black pearl, motolights running lights, Mean City Cycles modified seat w/adjustable backrest, 360 adjustable highway defiance pegs, defiance grips, flash2pass garage door opener.....buncha other stuff that nobody really cares about but me
SharkBite is online now
post #72 of 87 (permalink) Old 02-26-2012, 02:40 AM
I was just installing a new J&M Rokker set up and found the brackets had eaten through my fairing (at 25k miles) with daylight pin holes under the wind screen. I did an epoxy fill on the fairing and cut the brackets 1/8" tapered to 1/4" respectively in the area associated with the wear. I also glued on a split 3/16" fuel line x 1 1/4" over the wear area on the radio bracket edges. This should make contact with the fairing at -1/16" tolerance of the original bracket.
I'll check it at +5k miles to see how the patch is holding up and report it here.
Fog Shark is offline
post #73 of 87 (permalink) Old 03-18-2012, 08:43 PM
tkbalt's Avatar
Anyone check a 2012?
tkbalt is offline
post #74 of 87 (permalink) Old 03-18-2012, 10:13 PM
ThunderBueller's Avatar
From this very thread:
Tom
2010 FLTRX--Primo paint set #83
2005 FXSTB--Sold. Gonna miss it!
2003 XL1200C--Sold
2002 Buell S3T Thunderbolt--Sold and much missed.
ThunderBueller is offline
post #75 of 87 (permalink) Old 04-02-2012, 07:33 PM
faststan's Avatar
I just had my outer fairing off for new bars. The radio bracket on my '11 RGU has rubber covering the radio brackets. I didn't find any wear on the fairing.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #76 of 87 (permalink) Old 10-22-2012, 12:11 PM
Ironrider's Avatar
Smile 09 road glide fairing
I pulled my fairing off and sure enough same inside damage as the rest of you all. Thanks for sharing. I used a dremel and siliconed a clear hose split on the supports for protection.
Ironrider
Ironrider is offline
post #77 of 87 (permalink) Old 11-10-2012, 12:18 PM
Had my 08 in for speakers under extended warranty and sure enough rubbing on both sides. So the only issue I have is, I don't put a lot of miles on my bike because I work a lot and health reasons so I'm in my extended warranty. My service manager says that nothing cosmetic is covered under extended. So because I didn't have my fairing taken apart until after my factory warranty ran out I'm screwed. He is going to call the MOCO on Monday and I will know then if it is getting replaced. If not I may trade it in on a 2012 Road glide. They are really trying to move them....
coiledup is offline
post #78 of 87 (permalink) Old 05-21-2013, 11:42 AM
I have a 07 RG and already purchased the rubber radio trim pieces. Do i have to cut the radio brackets because the reason they are so tall to begin with is ti resist vibration and movement so i think with the ruber on them i'll be good.
ORANGERG121 is offline
post #79 of 87 (permalink) Old 05-21-2013, 11:48 AM
Clean&Sober's Avatar
Thanks, I'm glad I got the 5 year warranty, I will have to got back and see if it's covered.
2013 FLTRX Custom, 16" back Hill Country apes. Full header Python Momba pipes with a stage1 kit. Boom Speakers. 11" gun smoke Windvest windshield
Clean&Sober is offline
post #80 of 87 (permalink) Old 05-21-2013, 12:18 PM
RoadieWingZ's Avatar
Yes, you need to trim the brackets down and then put rubber strips on. I tapered mine on the outer front edge so the line matches angle of fairing better. Do a parts lookup on the old versus new radio brackets and you'll see how the new ones are tapered relative to the old.
Road Glides Rule!!!
2009 Vivid Black FLTR, Gold Flame collection, Cee Bailey 18" TRSSC Dome, BOOM speakers, Kury FB extensions, Heritage Style bars
RoadieWingZ is offline
