How to Find your Diagnostic Trouble Codes - Page 2 - Road Glide Forums
 6Likes
post #11 of 39 (permalink) Old 05-30-2011, 12:30 PM
TAuston's Avatar
Originally Posted by rodman4106 View Post
Being the smart guy that I am (lol) I decided to change by handlebars on my 09 and guess what happened?? I get a E light and cruise light changes colors between red and green. I took it back apart and everthing looks ok. I followed the procedure for clearing codes but still get code 1510 2122 2138. Which is the throttle grip sensor.
My question is what are my options?? Hard wire or should I repace the throttle grip sensor??
I appreciate any help you can offer
Bill
I wouldn't mess around with the throttle grip sensor. I would change it if it was mine. I just swapped handle bars on my 2010 and messed the throttle grip sensor up when installing. Mine had connectors (mid way on harness) on it that broke while pulling the wires through the bars. I went to my local dealer and they have another one that doesn't have the (mid way) connections. Installed a whole lot easier! Did cost me $80.00 for that mistake though.
2010 FLTRX
TAuston is offline
post #12 of 39 (permalink) Old 05-30-2011, 12:45 PM
Bill
Pull it apart and hardwire it . More than likely your problem is in the little green connection or lack of. All those codes refer to throttle sensor error.
2010 FLTRX , Stage 1, 13" Madstad, Mono tubes, SuperShox Heritage style bars. Alpine CDE-HD149BT,Soundstream Picasso Nano Series PN4.520 , 5X7,6.5 Infinity Kappa speakers
Big_gary is online now
post #13 of 39 (permalink) Old 05-30-2011, 01:42 PM
Smile
You were right Big Gary. Pulled apart and hard wired them together. Fixed the problem. Thanks for your help.
rodman4106 is offline
post #14 of 39 (permalink) Old 05-31-2011, 09:33 PM
Don't ask how I knew . lol There's only been a few that changed out the TBW handle bars that did not have some type of problem with the inner handle bar connector at first . I was not one of them . Cheers.
post #15 of 39 (permalink) Old 06-24-2012, 12:11 PM
texas glide's Avatar
I was looking for codes this morning because the scooter started missing out of the blue on the way home from work Friday. Well I have a crank sensor issue according to the codes. The question I have is why are my speedo and tach light still own 20 minutes later.
[SIGPIC]2011 FLTRX Vivid Black
103" V&H Power Duals Slash Cut Rounds Ness Big Sucker2 PV WO 515
texas glide is online now
post #16 of 39 (permalink) Old 11-23-2012, 05:42 PM
Ironrider's Avatar
great info. Thanks
Ironrider
Ironrider is offline
post #17 of 39 (permalink) Old 11-23-2012, 05:51 PM
Ironrider's Avatar
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
P0605 ECM FLASH Memory Error
P0603 ECM EEPROM Memory Error
U1300 ECM Serial Data Low
U1301 ECM Serial Data High
U1097 Loss of Speedometer Serial Data to ECM
U1064 Loss of TSM/FSFM Serial Data to ECM
P1003 System relay contacts open
P1002 System Relay Coil High/Shorted
P1001 System Relay Coil Open/Low
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P0373 CKP Sensor Intermittent
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0374 CKP Sensor Synch Error
P1511 Throttle actuator control power management failure of throttle control actuator
P1600 EFI Module Processor Internal Error
P1270 TGS Validation Error
P2107 EFI Module Processor Internal Fault
P2101 Throttle actuator control motor circuit range/performance error
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2138 TGS Correlation Error (Twist grip sensor)
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0222 TPS2 Low
P0223 TPS2 High/Open
P2135 TPS Correlation Error
P2119 EFI Motor Throttle Body Range Performance
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2176 EFI Closed Position Not Learned
P1514 Air Flow Fault
P2105 EFI Forced engine shutdown
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High
P0572 Brake Switch Low
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P1351 Front Ignition Coil Driver Open/Low
P1354 Rear Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1355 Rear Ignition Coil Driver High/Shorted
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open..
P1356 Rear Cylinder No Combustion
P1353 Front Cylnder No Combustion
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P0131 Front Oxygen Sensor Low
P0151 Rear Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0152 Rear Oxygen Sensor High
P0134 Front Oxygen Sensor Inactive
P0154 Rear Oxygen Sensor Inactive.
P1510 EFI Limited Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P0577 Cruise Control Input High
U1300 Serial Data Low
U1301 Serial Data High
U1016 Loss of ECM Serial Data
U1255 Serial Data Error
B1142 Smart Security System Internal Fault
B1135 Accelerometer Failed
B1136 (HFSM) Accelerometer Tip Test Error
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
B1134 Starter Output High
B1121 (TSM) Left Turn Output Fault
B1121 (HFSM) Left Turn Output Open
B1122 (TSM) Right Turn Output Fault
B1122 (HFSM) Right Turn Output Open
B1123 (HFSM) Left Turn Output Short to Ground
B1124 (HFSM) Right Turn Output Short to Ground
B1125 (HFSM) Left Turn Output Short to Battery
B1126 (HFSM) Right Turn Output Short to Battery
B1143 (HFSM) Security Antenna Short to Ground
B1144 (HFSM) Security Antenna Short to Battery
B1145 (HFSM) Security Antenna Open
B0563 Battery Voltage High.
B1131 (HFSM) Alarm Output Low
B1132 (HFSM) Alarm Output High
B1141 (TSM) Ignition Switch Low/Open
B1141 (HFSM) Ignition Switch Low/Open
The following came from the ABS section of the 2008 Electrical Diagnostics manual- hopefully close enough until something better comes available...
C0562 Device voltage low
C0563 System voltage high
C1014 ECU internal fault
C1017 Pump motor power circuit open fault
C1018 Pump motor ground high resistance fault
C1021 Front wheel speed sensor equals 0
C1023 Rear wheel speed sensor equals 0
C1025 Front wheel speed signal intermittent
C1027 Rear wheel speed signal intermittent
C1032 Front wheel speed sensor circuit open or shorted
C1034 Rear wheel speed sensor circuit open or shorted
C1042 Pump motor open
C1043 Pump motor stalled
C1055 ECU internal fault
C1056 ECU internal fault
C1057 ECU internal fault
C1061 ECU internal fault
C1062 ECU internal fault
C1065 ECU internal fault
C1066 ECU internal fault
C1094 Front brake switch always on
C1095 Front brake switch open
C1118 ECU internal fault
C1121 ECU internal fault
C1151 Front wheel release too long
C1153 Rear wheel release too long
C1158 Calibration programming required
C1206 Wheel speed sensor frequency out of range
C1208 Wheel speed sensor frequency out of range
C1212 Front or rear brake not applied with decel
C1214 Rear brake switch always on
C1216 Rear brake switch open
U1300 Serial data low
U1301 Serial data open/hi
Rattletrap likes this.
Ironrider
post #18 of 39 (permalink) Old 11-26-2012, 04:05 PM
please help
I've been having the check engine no throttle problem for years on my 09. Every time I take it in they're "unable to duplicate" the issue. I was able to retrieve the codes but am unable to clear them. I followed the instructions in the sticky but no matter how long I hold the button it just reads "end" and never says clear. What am I doing wrong?
09 FLTR
07 BUSA
03 FXDL
apbtlvr is offline
post #19 of 39 (permalink) Old 11-26-2012, 04:25 PM Thread Starter
You have to clear each code separately for example when you are in the "P" mode of the DTC's and it show 2 codes you have to clear the first code first so you need to hold the reset button until that code comes up as clear then you can proceed to the 2nd code and clear that code then when that mode of the DTC's shows no codes then you can go to the next DTC mode . You can't clear all the codes from a DTC mode in one action. After all the codes are cleared turn of the ignition to exit the DTC mode and then check again for codes by entering the DTC mode again. You can clear the codes in a DTC mode in any order just as long as you clear 1 code at a time.
post #20 of 39 (permalink) Old 11-26-2012, 04:29 PM
Ironrider's Avatar
Good stuff
Sent from my MB860 using Motorcycle.com Free App
Ironrider
