How to Find your Diagnostic Trouble Codes - Page 3 - Road Glide Forums
 6Likes
post #21 of 40 (permalink) Old 11-26-2012, 05:05 PM
whew
Thanks so much!!!
09 FLTR
07 BUSA
03 FXDL
apbtlvr is offline
post #22 of 40 (permalink) Old 11-26-2012, 05:27 PM Thread Starter
Originally Posted by apbtlvr View Post
Thanks so much!!!
Glad you got it figured out . For your throttle problems you should read the sticky on HD service bulletin TT418A and it will explain the problem and provide you the fix.
post #23 of 40 (permalink) Old 04-02-2013, 08:55 PM
code BUS er
I went through the outlined steps and the code I get is BUS er and it will not pull any other code nor will it clear the code. o4 cvo 103
pcarter79 is offline
post #24 of 40 (permalink) Old 04-03-2013, 12:09 AM Thread Starter
A 2004 model has a older ecm that needs a scanilizer to read and clear the codes. You can use a jumper and read the codes by counting the flashes of the engine light but the only way to clear the codes without a scanilizer is to cycle the ignition on/off 50 times.
post #25 of 40 (permalink) Old 04-03-2013, 01:52 AM
AWESOME info. Thanks!
Snowman7 is offline
post #26 of 40 (permalink) Old 08-25-2013, 07:24 PM
Used as intended
Thanks for posting this! I just had a clutch cable replaced yesterday at 3800 miles on my 08 (I'm 2nd owner) which was supposed to be a fix to my cruise randomly shutting off along with a couple other issues. All seemed to be fixed. Had her out today for the first long ride and used the cc just fine along with using the resume function for the first time. Stopped for a bit and when I tried to set it the cc would set then turn off. Then it would give the green light as if it were set but it wasn't. Then I noticed the cel was lit and began to look/listen for anything different. Nothing seemed out of the ordinary, thankfully, except the cc set/resume button seemed slightly cock-eyed. Got home and knew just where to go. Found the diag instructions and got the code P0577. Not sure if the button is truly cock-eyed but quite a coincidence. Someone did post on that code that it was their set/resume switch so possibly that is my issue as well. But thanks a ton for putting this info on here! And thanks to the other posters for sharing!!!
mullermj is offline
post #27 of 40 (permalink) Old 09-28-2013, 01:30 PM
getrdone's Avatar
Question Engine codes??
I see some of you posted on engine codes and I was wondering if you could help me with my codes.
My check engine light comes on when I first turn the ignition on then goes out after about four seconds like its suppose to. I start the bike and the check engine light comes on again for about 5-6 seconds then goes out. This only happens when I start the bike. Light never comes back on after its started and running.
I ran the code check and this is what it shows.
P-Code po563,po134,po154-no part numbers?
t-Code u1040-pn67348-04d
b-Code co562-pn32836-09a
Hope you can help and thank you if you can.
2012 Road Glide Ultra.
Life is good but God is Great!
getrdone is offline
post #28 of 40 (permalink) Old 08-12-2014, 05:33 PM
SHREDSURF's Avatar
Originally Posted by ironmark View Post
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's . The radios DTC's are retrieved through the radio and displayed through the radio display .
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
HUGE HELP, THANK YOU! This little bit of info and instructions saved me at least $250.00 at the stealership!
I've had this "limp mode" problem for a while now.
I'll be riding along and the throttle becomes unresponsive, RPM's drop to 1500, the red security key lights up as does the check engine light, I am forced to pull over, shut the bike down and restart it...annoying, but more dangerous than anything else.
I just ran the internal diagnostics test myself using the instructions above and cleared all of the following errors:
P1009 - Incorrect Password
P1511 - Throttle actuator control power management failure of throttle control actuator
P2135 - Correlation Error
B1121(TSM) - Left turn output fault
B1121(HFSM) - Left turn output open
B1122 (TSM) - Right turn output fault
B1122 (HFSM) - Right turn output open
The part #'s associated the error codes were as follows:
Pn - 32933-09
Pn - 68920-07
I will assume that since I've cleared all of the error codes, I'm good?
I will re-check them once I ride again and the limp mode occurrence is intermittent so I'll see what happens while riding.
Thanks again IronMike!!
'09 FLTR - *Red Hot Sunglo*
SHREDSURF is offline
post #29 of 40 (permalink) Old 03-19-2015, 11:13 PM
I can't seem to find what it means when I get PN 32933-09 after it reads the DTC of P0562 on the DTC. Anyone have any ideas?
Bruce
bikepsych, 2017 RoadGlide Ultra
Bone Stock
bikepsych is offline
post #30 of 40 (permalink) Old 03-20-2015, 09:38 AM Thread Starter
Bruce
PN32933-09 is the part number and means nothing when it come to the diagnostics, this will always comes up when you scroll through the diagnostic programs.
There is a list of DTC's in the troubleshooting section which will tell you what the DTC means , your PO562 DTC means low battery voltage.
