Installed a CVO Rear Fender on my 2011 RGU - Page 3 - Road Glide Forums
post #21 of 36 (permalink) Old 01-05-2013, 07:44 PM
Originally Posted by Q-Hog View Post
Looks good. Do you have a side view of your bags w/extensions?
They are the HD extentions that came on the older CVO models.
rlaf75 is online now
post #22 of 36 (permalink) Old 01-15-2013, 03:29 PM
Bluefilhd's Avatar
Originally Posted by rlaf75 View Post
Not to do any hi jacking but alil FYI, the parts can be purchased separately for alot cheaper than the fender set up from the MoCo. I used my stock fender and bought everything else including the bag extentions for about $600ish. I had my buddy color match and spray it.
That looks good. We're did you get the parts from? All one source or multiple?
Bluefilhd is offline
post #23 of 36 (permalink) Old 01-16-2013, 06:54 AM
Looks good lets see a side view left and right
DragoBikeWorks is offline
post #24 of 36 (permalink) Old 01-16-2013, 07:17 AM
Garemlin's Avatar
I really need to stay away from the forums or I am gonna go broke. I just ran across a thread on the other forum about the V-Twin Mfg CVO style slant saddlebags.
Custom Stretched ABS Extended Saddlebags for Harley Touring
These are very tempting but I would have to go with the CVO fender set-up to complete the look. If I did go with the CVO fender I would prolly go with the International version to retain the actual taillight. Won't be this year for sure.
Garemlin is offline
post #25 of 36 (permalink) Old 09-01-2013, 08:53 AM
Easyryder01's Avatar
Rlaf75 bike looks real sweet and the extensions are growing on me, I wonder if the darker the color of the bike will make the extensions blend in or stand out ? Also the black button on the rear lower fender have you found anything to replace it with ?
2017 RGS Velocity Red
Easyryder01 is offline
post #26 of 36 (permalink) Old 09-01-2013, 09:25 AM
Originally Posted by Easyryder01 View Post
Rlaf75 bike looks real sweet and the extensions are growing in me, I winder if the darker the color of the bike will make the extensions blend in or stand out ? Also the black button on the rear lower fender have yyou found anything to replace it with ?
Thanks. I did replace that lil black button. I used the CVO fairing skull medalion. The button is simply stuck on with double sided tape, so is the lil skull.
post #27 of 36 (permalink) Old 09-01-2013, 10:18 AM
I believe mine is not an adhesive piece its clipped on.
post #28 of 36 (permalink) Old 09-01-2013, 10:34 AM
skratch's Avatar
your bike looks good as well as does the op's. but the big difference in the route you took vs the 'kit' is the location of the license plate. using the stock fender puts the license plate up higher on the fender, vs the cvo style which has the plate closer to the tip. for some people that may be worth the extra couple hundred bucks. others not so much.
skratch is offline
post #29 of 36 (permalink) Old 09-01-2013, 10:51 AM
It still should be stuck on. It covers a resessed divot that has a bolt through it to bolt a bracket inside the fender.
Thanks and you are correct. The only difference is the plate location. Mine sits about 6"s higher on the fender then a factory CVO or the fender kit. To me it wasnt worth replacing the fender but to each their own
post #30 of 36 (permalink) Old 09-01-2013, 10:55 AM
This is whats under the lil black button on the rear fender
