Add a Siren to your Factory Security for $6 - Page 22 - Road Glide Forums
 18Likes
post #211 of 451 (permalink) Old 09-21-2012, 07:02 PM
Nchoman's Avatar
Picked up a couple of the alarms on Amazon today while I was at work. Still might swing into RS to pick up the pins though. With all the theft going on lately it wouldn't hurt to have some extra deterrence. Going to hook up my brother-in-laws Crossbones too.
12' BBP RGUltra, dual dragulas, tman tq555's, tmax, zippers air, daymakers, 12.5 apes, odds and ends
Nchoman is offline
post #212 of 451 (permalink) Old 10-07-2012, 10:08 AM
Methos1979's Avatar
Yet another guy who did this mod and as all have reported before me, it is is very easy and inexpensive. I ended up buying two alarms and the 9-pin connector kit. I mounted both alarms one above the other in the slot under the left side cover. I did not drill holes to use the slot for the original connect, just tie wrapped everything back into convenient places. It works very well and is very loud for sure. Easy, cheap mod. Highly recommended.
2013 Road Glide Custom CVO in Roman Gold/Burnt Emerald, Le Pera Maverick, Vance & Hines Power Duals, SERT, MadStad 13", Kury ISO grips & Scythe mirrors.
Methos1979 is offline
post #213 of 451 (permalink) Old 10-08-2012, 02:20 AM
Just did mine tonight.....installed two....one on each side
Thanks for the info to get this mod done.
_Nem_ is offline
post #214 of 451 (permalink) Old 10-10-2012, 06:15 PM
Do any of you guy know where the siren wire is on the 2005 road glide
Thanks for your help
badboyindc is offline
post #215 of 451 (permalink) Old 10-12-2012, 08:19 PM
Just finished up, how cool... works as advertised, and easy too. thanks for the tip and pictures.
flhtcm is offline
post #216 of 451 (permalink) Old 10-13-2012, 02:34 AM
RoadGlideRider's Avatar
Originally Posted by TLWiz View Post
The HD siren has it's own battery so that it keeps screaming even if the battery cable is pulled. That's the difference I know of. It is just like H-D to not include a siren with the alarm system, but to charge extra for it as an add on.
Beside the battery back-up, the Siren II has the transmitter and antenna for the pager included in the siren at no extra cost.
Besides, Harley has the alarm system as an optional accessory, not standard equipment (except for the CVO or other High $$$ models). So it would not be expected to have the alarm siren included at no cost.
Some might ride a motorcycle protected with an alarm worth only $6, but I don't.
RoadGlideRider is offline
post #217 of 451 (permalink) Old 11-17-2012, 09:38 PM
bikerglasses's Avatar
Any idea why when I added the Harley siren it doesnt sound or chirp?
Sent from my SCH-I535
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, pcV
bikerglasses is offline
post #218 of 451 (permalink) Old 11-17-2012, 10:20 PM
It has been a setting on the alarm from the original Factory Alarm introduced 2001.
You can set it to always chirp. Or, just when the alarm is activated.
In 2001, when introduced, Harley had Retro-Kits for bikes back to 1997.
I put one on my 1998 Ultra. I set the siren to only sound when activated.
I have it set the same on my 2009 RG.
I don't know if the Radio Shack siren can be set the same.
post #219 of 451 (permalink) Old 11-17-2012, 10:31 PM
but when I shake the bike the lights flash but gets no sound.
post #220 of 451 (permalink) Old 11-17-2012, 10:51 PM
That means you don't have the siren installed or it is not connected correctly.
The siren is not included with the alarm. It is another accessory to buy.
If you didn't install one, look under the right side panel. That is where is mounted.
If you don't see one, you don't have it.
