Question on Greasing the Steering Head Bearing - Page 2 - Road Glide Forums
post #11 of 33 (permalink) Old 11-05-2012, 06:34 PM
hotrodad's Avatar
Originally Posted by Teagatron3000 View Post
Got it done last night. Was a one beer job. Real simple. Having the battery operated grease gun made it sweet. Just hooked it up and pulled the trigger. Kept checking around the top and bottom of the steering neck for grease to come out. I should be good to go.
TEAG
Please follow up after a while and let us know if you see any gobs of grease oozoi out days, weeks or months later. i think you were lucky scoring an electric grease gun with a full tube. Pump away! When you see grease starting to ooze out giver a few more to be sure you pushed all new grease through those bearings. You may never have to lube again considering what moco factory ships them out like.
I can not find a nipple on my '05. Any suggestions?
enjoy the ride
HRD
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #12 of 33 (permalink) Old 11-05-2012, 07:39 PM
Triplej's Avatar
Originally Posted by hotrodad View Post
TEAG
enjoy the ride
HRD
According to the parts diagram, item number 40 should be there on the left side of the frame in the neck of the steering. Since they don't always grease the bearings, maybe the assembler figured you did not need one
http://partsfinder.onlinemicrofiche....D--JIFFY-STAND
Triplej is offline
post #13 of 33 (permalink) Old 11-05-2012, 07:53 PM
HD_Shock's Avatar
I used Lucas Red and Tacky about 5k miles ago - no mess whatsoever even after my 2300 mile Sturgis trip. On a side note, I pumped quite a bit but could never get it to squeeze out from the top bearing ... just kept coming out from the bottom. Anyone else have this issue?
-phil
2011 FLTRX 103
HD_Shock is offline
post #14 of 33 (permalink) Old 11-05-2012, 07:57 PM
Triplej's Avatar
You can sometimes take a piece of rope or thicker gauge wire and wrap it tightly around the bottom bearing gap, closing the gap, and it will force the grease up to the top bearing.
Triplej is offline
post #15 of 33 (permalink) Old 11-05-2012, 07:59 PM
tmd
What, wheres the Amsoil guys. Surprised they aren't jumping in here claiming how your steering will lockup and the bearings will seize if you use anything but their grease.
Pick your favorite color of grease and squirt it in there till it oozes out of the upper and lower cups. You'll have to wipe it off a few times after some riding but that perfectly normal.
tmd is offline
post #16 of 33 (permalink) Old 11-05-2012, 08:03 PM
HD_Shock's Avatar
Thanks, Triplej. I actually tried something similar with rolled up paper towels -had it stuffed all the way around nice and tight but the grease still found it's way out. I'll try the rope next time.
-phil
2011 FLTRX 103
HD_Shock is offline
post #17 of 33 (permalink) Old 11-05-2012, 08:10 PM
Triplej's Avatar
The steering head bearings locked up on my last bike when I put Amsoil in the Tranny, WTF??
Triplej is offline
post #18 of 33 (permalink) Old 11-06-2012, 06:34 PM
rageglide's Avatar
enjoy the ride
HRD
Look under the bracket that's holding up the fairing, on left side. I took a grinder to the bracket for clearance and put a 90 degree fitting on there... no way you could get to it without some very low profile special fitting. (if at all).
And I'm not one who believes any grease is good grease. Some greases don't work as well in a hammering non-rotating timken. Harley had neck bearings failing at low mileage and great deal of regularity with the Springer front end (not same as ours obviously), but after a change in grease they were able to get that problem under control. I believe there was a harley internal tech note for it too. Want to say this was late 90's. Call me stubborn... but the HD branded grease is all I've ever used since.
rageglide is offline
post #19 of 33 (permalink) Old 11-06-2012, 08:31 PM
Methos1979's Avatar
I had the opposite problem with the grease coming out of the top but not the bottom.
2013 Road Glide Custom CVO in Roman Gold/Burnt Emerald, Le Pera Maverick, Vance & Hines Power Duals, SERT, MadStad 13", Kury ISO grips & Scythe mirrors.
Methos1979 is offline
post #20 of 33 (permalink) Old 11-06-2012, 08:53 PM
Torquey's Avatar
You just might be the first guy on this forum who, although not discharging a firearm, pulled the trigger without purchasing a single thing. Congratulations!
Torquey is offline
