Changing to a 30T transmission sprocket - Road Glide Forums
post #1 of 5 (permalink) Old 11-07-2012, 08:28 AM Thread Starter
Can anyone tell me if they have done this modification, if they like it and how difficult it is for someone to do? Some people have talked about changing belts, but the kit that I was looking at changed out the chain.
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #2 of 5 (permalink) Old 11-07-2012, 09:30 AM
FrankieB's Avatar
not that hard to do, will need to pull the inner and outter primary off and everything in between. The job will require a few speciality tools.
06 RK
11 RGU
FrankieB is offline
post #3 of 5 (permalink) Old 11-07-2012, 03:54 PM
HarleyJack's Avatar
if you are changing out the chain then you are doing the compensator change in the primary , not the final drive pulley
if you change the compensator , you will lose cruise control
JtB
2011 Ultra
HarleyJack is offline
post #4 of 5 (permalink) Old 11-07-2012, 06:36 PM
I changed to 30tooth on a 07.On that year you change to what's called the international belt If I had gone only one tooth change the stock belt would have worked.It made it easier to get in 6th gear a little sooner for highway riding. Look on Andrews Cam website or S&S they have info that's very useful also Bakers.they will list years and gears and the amount each tooth drop and how it will affect your ride
watty is offline
post #5 of 5 (permalink) Old 11-07-2012, 07:14 PM Thread Starter
I guess that's what I was talking about is changing the primary sprocket from 32T to 30T to eliminate the compensator.
