Adding Accessory Outlet - Road Glide Forums
post #1 of 2 (permalink) Old 11-27-2012, 08:43 AM Thread Starter
jimmyray11349's Avatar
I have a 2010 RGC. I want to add Accessory Outlet in my fairing right side pocket similar to one in left fairing pocket. Where do I power it inside fairing?
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #2 of 2 (permalink) Old 11-27-2012, 09:16 AM
SurlyBoy's Avatar
There's an accessory wire and ground zip tied to the headlight wiring harness. Can't remember what color it is, maybe orange and white? There are spade connectors already crimped on the ends. I used it to power my bar end heaters.
While I was in there I ran an extra wire from there into the speedo housing. It's not hooked up to anything right now but it means I don't have to take off the fairing in order to get to it if I need to add an accessory.
SurlyBoy is offline
