Winter 2012/13 Upgrades: Whar r ur plans? - Page 6 - Road Glide Forums
post #51 of 143 (permalink) Old 11-03-2012, 11:27 AM
Methos1979's Avatar
Once the big snow arrives (hopefully it won't !) and the driveway is packed snow and ice then I'll start the following winter projects:
Definites:
Heritage or KW +2 bars
New grips while I'm at it
LED turn/brake light install
Maybes:
Angled rear crash bars
Long term:
Madstad
2013 Road Glide Custom CVO in Roman Gold/Burnt Emerald, Le Pera Maverick, Vance & Hines Power Duals, SERT, MadStad 13", Kury ISO grips & Scythe mirrors.
Methos1979 is offline
post #52 of 143 (permalink) Old 11-03-2012, 11:49 AM
mmcmsw's Avatar
waiting
Waiting for the snow to fly, then off to the races,
Front Fender and Fairing to the paint shop to "fix" (spelled repainted) the chips I received from SFO a pickup. I"ll never do another custom paint job.
Have my console and tranny insert painted black, silver and orange by the same lady that did my floorboards,
Powder coat run for my "Chainsaw" floorboards
Install my headwinds spot/signal lights.
Then ride the darned thing.
Trailers are for Boats!!
mmcmsw is offline
post #53 of 143 (permalink) Old 11-03-2012, 12:15 PM
JKRSDETROIT's Avatar
putting on the extended bags that are sitting in box. Put on the black engine cover kit thats in a box when I do the engine mods. Engine mods... Probably Dragos stage 2 CNC heads, 10.5:1 pistons, 58mm throttle body and hi flow injectors and set of cams to be determined. LED headlights. Rear CVO fender/fascia if I have money left over.
JKRSDETROIT is offline
post #54 of 143 (permalink) Old 11-03-2012, 12:19 PM
Brent376's Avatar
Planning on: removing upside down scallop and pin striping, install dash lights, new day maker, paint engine black, put black primary cover on, re-route some wires, new rubber front and back, maybe hydrographic the inner fairing
JAWZ 2 / 2015 RGS /Custom Paint
Brent376 is offline
post #55 of 143 (permalink) Old 11-03-2012, 12:21 PM
btfochad's Avatar
1. Torn between black or chrome forks
2. After I decide the forks getting mono-tubes for sure
3. May get my heads done
4. May get the dragos 2-1 exhaust
5. May switch from 14" to 16" apes - too many choices that I like
2010 Road Glide
14" Apes
Knight Prowler TW-555 Cam
btfochad is offline
post #56 of 143 (permalink) Old 11-03-2012, 12:49 PM
Rowdy's Avatar
Attachment 16360
Attachment 16361
Those lights look killer, any more info in them?
Rowdy
Rowdy is offline
post #57 of 143 (permalink) Old 11-03-2012, 03:01 PM
mmcmsw's Avatar
Rowdy
His Hard Copy catalog is bit better.
These are called Revolver Vampires. I had them built special order. I am wiring so the signals are not running lights, and the spots run off of the ACC switch.
http://www.headwinds.com/ talk to Joel.
Here are the RG lights.
http://www.headwinds.com/mm5/merchan..._Code=01020213
I had mine special ordered with the pointed (vampire) eyebrow so it would blend with my front fender's black point, and the silver for well.... silver.
mmcmsw is offline
post #58 of 143 (permalink) Old 11-03-2012, 04:12 PM
Installing 124" S&S
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #59 of 143 (permalink) Old 11-03-2012, 07:29 PM
hittman's Avatar
Heritage Bars
Wheels/Tires
Lower Fairings
Remove Cat
Tour Pak
CB Windshield
"It just cost a little more to go first class"
hittman is offline
post #60 of 143 (permalink) Old 11-04-2012, 12:43 AM
Colin1966's Avatar
I have a bunch of mods for the winter.
I just picked up the RG in June and it was pretty much stock.
removing the rear signal & brake lights & licence plate to clean up the back end.
1) Extended hardbags w/cut out for TD's
2) extended fender & fillers w/plasma rods (turn/run/stop)
3) Stealth III license plate
3) cam swap SE 204's w/adjustable pushrods
4) Progressive drop-ins -lower 2"
5) strip/sand & polish legs.
6) 21" front wheel
7) Into Lonewolf for a tune
just done:
Heavy Breather
MGS true duals
TTS
C&C solo w/backrest
all I need to do is find the right 21" front wheel, any1 looking to sell, let me know what you have got.
Colin
Feb 14/1994-Nov 29 2012
Rest in Peace sweetheart.
Colin1966 is offline
