FLTRX rear turn sigs/plate bracket on a FLTRU - Road Glide Forums
post #1 of 16 (permalink) Old 11-22-2012, 09:32 AM Thread Starter
HellInABucket's Avatar
Folks, I want to relocate my license plate on my Ultra below the signal bar.
(Familiar with Softbrake, prefer not to go that way if I dont have to)
I'm looking at part number 53702-04A.
According to the fitment info, it wont fit a 2013 FLTRU.
It appears to me to be the same parts as on the FLTRX, and the Street Glide.
I'm thinking about ordering OEM replacement parts for the FLTRX.
Does anyone have a similar kit on their Ultra?
, Fuel Moto 107
HellInABucket is offline
post #2 of 16 (permalink) Old 11-22-2012, 10:05 AM
tdkkart's Avatar
Well, to start with, the kit you reference is for the pre-08 "old" frame bikes with the narrower rear fender, 09 and later bikes have the wide fender, completely different profile so none of the parts swap.
Shoot me a PM in a day or so, I've got a complete Street Glide fender with lights here, as well as my Ultra, I can give you a better idea of what will swap, I don't remember off the top of my head, and the SG fender is in the attic of my shop, won't get up there today.
tdkkart is offline
post #3 of 16 (permalink) Old 11-22-2012, 10:28 AM Thread Starter
Is the 2013 FLTRX rear fender different from the 2013 FLTRU rear fender?
If not, then the light/plate assembly from the 2013 FLTRX should fit on a 2013 FLTRU, right?
, Fuel Moto 107
post #4 of 16 (permalink) Old 11-22-2012, 11:17 AM
tdkkart's Avatar
The are indeed different, the Ultra fenders have a big-arse hole/bracket under the big light, and it seems to me SG/FLTRX has a couple holes under the light bar that the ultra fender does not.
Not sure if just the license plate bracket will both on to either fender, I'll check it out over the weekend if you send me a reminder, I'm sequestered to the house today.
tdkkart is offline
post #5 of 16 (permalink) Old 11-22-2012, 11:32 AM
skratch's Avatar
yes, the rear fender is different. the fltru fender has 'dimples' and is drilled for the center mount taillight, while the fltrx fender is smooth and is not drilled.
edit: tdkkart beat me to it....
on the fltrx, the license plate doesn't bolt to the fender. it bolts to the backside of the taillight bar. not sure how it mounts on the ultra version.
skratch is offline
post #6 of 16 (permalink) Old 11-22-2012, 11:52 AM Thread Starter
Will do, thanks. Looks like I'm headed back to the Softbrake/Radiantz method.
, Fuel Moto 107
post #7 of 16 (permalink) Old 09-11-2014, 09:02 AM
GermanyBert's Avatar
Thread RESURRECTION!
I am thinking the 53702-04 will work. This is the same kit they use on all the Touring bikes here in Germany since the plates are too big to fit under the Tour Pak. We are talking about 8 x 8 inches. They use it even on the 13s. Don't know about the 14s.
While the fender did widen, the taillight and light bar did not. The fender has dimples for the lightbar to fit. I think I am gonna give it a try.
GermanyBert
2011 Road Glide Ultra
2002 Sportster 883/1250 Stage II
GermanyBert is offline
post #8 of 16 (permalink) Old 09-11-2014, 09:07 AM
Yup...just checked. Europe uses the same kit for 2014. The only difference I see is an A at the end of the American part number. The Euro part number does not have the A. Hmmmmmm.
GermanyBert
post #9 of 16 (permalink) Old 09-11-2014, 09:20 AM
Freaky's Avatar
Check out the 09 model RG for parts info. I have an 09 and am guessing mine is the set up you are looking for and might work for you with what you are trying to do.
Freaky is offline
post #10 of 16 (permalink) Old 09-11-2014, 09:29 AM
Harley-davidson.com does not show the kit for 2009 but it would not be a relocation kit since that was the stock set up.
Found this pic. Looks like it should fit.
GermanyBert
